Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
noob MT question
Old Nov 27, 2007 | 01:01 PM
three29's Avatar
noob MT question
Wide open throttle (WOT) refers to an internal combustion engine's maximum intake of air and fuel that occurs when the throttle plates inside the carburetor or throttle body are "wide open", providing the least resistance to the incoming air. In the case of an automobile, WOT is when the accelerator is depressed fully.
At WOT, manifold vacuum decreases. Ideally, to preserve driveability and fuel economy, manifold vacuum should not fall any lower than 1" (mercury).
Sorry you guys, im kind of a noob car enthusiast.. I love my car, but i wont bs because i dont know anything about cars... so please bear with me
Ok so Im reading up on how MT saves gas over AT, and Im not really getting one of these points:
Driver control. Certain fuel-saving modes of operation simply do not occur in an automatic transmission vehicle, but are accessible to the manual transmission driver. For example, the manual-transmission vehicle can be accelerated gently, yet at wide open throttle (WOT), by means of shifting early to a higher gear, keeping the engine RPM in a low power band. By contrast, in an automatic transmission, the throttle position serves as the indicator of how fast the driver wishes to accelerate. If the accelerator pedal is floored, the transmission will shift to a lower gear, resulting in high engine RPM and aggressive acceleration. The thermodynamically efficient combination of open throttle and low RPMs is unavailable to the automatic transmission driver.
I always thought flooring the pedal, no matter what the situation = more waste of gas. When you depress the pedal all the way, you maximize airflow and FUEL INTAKE, so arent you using more gas when you floor your pedal? the computer says that our fuel economy decreases the further i depress the gas pedal..
If I am going at say around 25km/h and I shift directly from 2nd gear to 5th gear, and floor the pedal, even though the revs are really low and Im accelerating really slow,
1) wikipedia is telling me is that the car saves more gas, while
2) our car is telling me that im getting low gas mileage becase im flooring the pedal which = lower gas efficiency.
wikipedia says that for MT in that situation saves gas, but the definiton of wide open throttle refers to maximum intake of air and fuel. How does that save gas, even if it reduces drag?
Old Nov 27, 2007 | 09:17 PM
mines hotter's Avatar
wikipedia does not have accurate info i could go on there and say it rains cream soda but it doesnt mean its true so watch where you get your info from ur best bet is to ask a mechanic or some 1 who really knows kuz im not to sure about that whole thing but shifting from 2nd to 5th i would imagine is not the best thing for your motor but who knows lol
Old Nov 28, 2007 | 12:38 PM
Blacksheepdj's Avatar
Wikipedia is nice to read, but don't base your beliefs on it. Always remember that anyone could have typed that info in.
Old Nov 28, 2007 | 12:48 PM
eg6motion's Avatar
yep, you can go write a wiki article on how to make gas from green beans and it will be published...
Old Nov 28, 2007 | 01:32 PM
nj_08_gts's Avatar
So you're saying that article was fake??? Great...all that time growing beans for nothing.
To the OP: WOT will eat fuel weather you're driving with a standard gearbox or an automatic...what your car is telling you is correct. A standard gearbox will only have an MPG advantage if you don't drive and shift like a doofus (i.e. going from 2nd straight to 5th gear and then flooring it).
Old Nov 29, 2007 | 06:41 AM
three29's Avatar
ok thanks for the answers guys~ i also got this response from another board:
At WOT, air/fuel mixture system are in demand and does not save gas a bit even in any gear because when the TPS is a 100%, it will tell the PCM to spray more fuel from the injectors to the combustion chamber, and of course more ram air is in demand. At 5th gear from 2nd, the engine will accelerate slower which means demand for fuel is low., and engine rotates slower so fuel burns longer that saves fuel. But putting in high gear with low speed will but load into the transmission gears.
Never skip gears!!!! That just hurts the transmission, the only time you should ever do that is when you're playing arcade games.
Nevertheless, don't worry about all the technical stuff and readings.
Just remember, try to use as much power to start the car off, and as low RPM as you can. Too little power, would mean more work for the car to get the car moving, you know what would happen. So it's all a matter of balance between power/energy and lower RPM. If you change from start off gear, 1st or 2nd, to 3rd too early, that stresses the tranny and the engine. Too late, would mean high RPMs, would stress your wallet.
it makes sense to me now
Old Nov 30, 2007 | 06:48 AM
eg6motion's Avatar
hehe, and you thought all those food drives wanted green beans for the homeless.....
Landshark
Outlander Sport
42
Feb 14, 2019 10:01 AM
JTCB
Jun 21, 2012 06:27 PM
SlipstreamFirst
16
Sep 5, 2009 07:08 AM
SRTRaceR04
Jan 6, 2007 09:18 PM
slt
16
Jul 30, 2006 12:54 PM
