Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
RRM Springs
Old Jan 12, 2008 | 06:22 PM
Eagles GTS's Avatar
RRM Springs
Did I hear somewhere that you have to cut some bumpstops. What are bumpstops? Basically I wanted to know if I can take off the rrm springs and replace them with the stock springs and the dealer never know I did anything.
Old Jan 12, 2008 | 06:52 PM
SLVROZ_03's Avatar
From what I saw today (installed Progress spings on my OZ), the bump stops are a large rubber "bushing" on the strut piston that basically stops the pistons travel. It's between the top mount and the base of the actual strut.
Well, I think you could pass inspection if the lowering isn't major...maybe just an inch or two. Then also the color would be the next obvious thing. My Progress springs are bright teal-ish in color...not a chance.
Good luck
Old Jan 14, 2008 | 07:45 PM
Eagles GTS's Avatar
so do you have to cut the bumpstops
Old Jan 16, 2008 | 11:53 AM
Blacksheepdj's Avatar
Yes, cut them.
Old Feb 9, 2008 | 09:47 AM
ashun22panda's Avatar
anyone have pictures as to how they look and how to cut them?
Old Feb 9, 2008 | 12:06 PM
I don't have pics, but I can tell you. It's a rubber piece connected to the dust boot. You'll see it on the shock rod. Should be pretty hard to miss, because there's not much rubber in there.
As for how to cut them - any way you can. The RRM instructions should clearly define what amount to remove. Last time I cut bump stops, it was just with a regular pocket knife and some sawing motions....
03lances
Nov 15, 2010 06:35 PM
BriK
Apr 15, 2010 10:08 AM
4WS Tuning
Jan 2, 2007 06:17 PM
lan_evo_mr9
Mar 10, 2006 11:43 AM
yellowlancer02
Mar 28, 2003 09:12 PM
