Logging Tools/ CEL readers
Old Mar 21, 2008 | 07:34 PM
DC_TypeR's Avatar
Who's using what? and what is working the best so far on the X?
Let's hear it!! I am in the market for some logging software/ CEL reader... and I don't wanna just jump on the first thing I see.....
Thanks,
Chris
Old Mar 22, 2008 | 02:12 AM
RazorLab's Avatar
I'm currently testing out the Innovate OT-1, which does both.
Old Mar 22, 2008 | 09:27 AM
PDXEvo's Avatar
Actron CP9185. Logs load cell, IAT#1 and #2 temps, and about 126 other PID's. Also allows me to reset codes, view the tale of the tape logs, and diagnose the different components of the cars system.
Old Mar 22, 2008 | 11:13 AM
evo_Eks's Avatar
does it show boost level too?
Old Mar 24, 2008 | 07:04 AM
psy-q's Avatar
As long as your driving an EvoX you could use an MSD Dashhawk (CANBUS only). It'll log, run performance tests, clear codes and show engine readings in realtime. I've tested mine on a EvoX and it does show boost, although not as accurately as a gauge due to the high update speed of the ECU.
Check MSD's website.
Old Mar 24, 2008 | 10:56 AM
PDXEvo's Avatar
It doesnt show Boost in PSI, but it does show MAP, Timing, RPM, Speed, ECU Load, ABS ECU Load, TPS, etc. You can determine boost based on MAP. The downfall with this tool is you only get a short log of 45 frames, which equates out to be log enough for you to do a few pulls. But generally you would just start the log, do a pull, and download to your PC.
Old Apr 1, 2008 | 09:09 AM
pltek's Avatar
how is the testing going, does it log the X basically?
Old Apr 1, 2008 | 11:59 PM
RazorLab's Avatar
I can't get the OT-1 to work correctly.
I think it was rushed to market and would urge people not to purchase it yet.
Old Apr 2, 2008 | 09:54 AM
PDXEvo's Avatar
Thanks for the update razor.
Old Oct 31, 2008 | 01:19 PM
Rguy's Avatar
Any updates to this?
Im about to buy a logging tool thats 95 bucks that I heard works with the EVOX..
Old Oct 31, 2008 | 01:36 PM
08EvoXGSR's Avatar
DashDaq (Drew Technologies), DashHawk isnt bad-but limited compared to the Daq, as for scanning, Actron's are great, but can get spendy. Oh, and use the zietronix WB to mate with the DashDaq, and its like the KY commercials
Yorgis_MR
17
Oct 23, 2011 03:46 AM
primetime
Aug 18, 2009 04:50 PM
gz_evo8
11
Jan 4, 2008 11:51 AM
jjm4life
Northeast Region
Dec 12, 2007 09:06 AM
Ultimateone
Aug 23, 2006 10:50 AM
