Evoscan question
Old Feb 9, 2009 | 06:02 AM
aiden1983's Avatar
Evoscan question
How do u log AFR with evoscan (when it comes out for the x)? How does it hook up to the WB? Thanks for any info here.
Old Feb 9, 2009 | 06:13 AM
binky's Avatar
Depending on the wideband you bought - they usually hook up to a computer RS-232 (a serial connection). You might have to solder a RS-232 connector on the wire from the wideband.
You can then hook your computer up to the serial port and select the correct COM port to log from.
-Bink
Old Feb 9, 2009 | 06:15 AM
nothere's Avatar
a serial to usb adapter from radio shack might be in your cards.
Old Feb 9, 2009 | 06:34 AM
binky's Avatar
Ya true - if your laptop is newer - most of them don't have RS-232 connectors anymore, just do what he said and grab a serial-to-usb adapter.
-Bink
Old Feb 9, 2009 | 08:08 AM
aiden1983's Avatar
-Bink
Will this cause my gauge not to function or be inaccurate? Can you just buy another sensor and bung? Will it be easier for me?
Old Feb 14, 2009 | 10:17 PM
BerserkerX's Avatar
Nope the gauge will not be inaccurate. Why spend that much money on buying another bung and sensor?? Lol it will most certainly not be easier man. If it does mess it up which mine did not. I would not worry about it. Because you are seeing it on the computer which is where you need it if you are adjusting and tuning.
I would leave it as is. Just buy a serial to usb adapter. Then you plug it in and select the comport that your computer will usually assign randomly. (mine always did) Then you open up the device manager and find the comport its assigned to and select that in evoscan along with the brand you have. Its as easy as pie man.
Let me know if that helped or if you need any more info.
Old Feb 15, 2009 | 08:25 PM
aiden1983's Avatar
thanks, when evoscan comes out I will have 100000 questions so I will just save them up .
