EvoScan 2.6
well i used it this morning and no connection issues but
1. tps value only goes up to 47 so i am confused
2. knock retard is stuck at 251
3. i dont see ability to log PSI
4. intake/exhaust vvt seems to be off shows up to 66deg in some instances and both intake/exhaust values are the same
5. it looks like all requests are CAN based so the tephra logging things are gone
6. my load in in excess of 4500 for a value so i am confused
i am sure that its a matter of updating data.xml file or changing formulas, but i cant keep up anymore
one suggestion i would make is the output log file only have the columns of data that is being logged
anyone else?
anyone else?
anyone else?
anyone else?
eeerrr stuck at work for another day again
well sorry if this is a newb question but do we have to select Mode23 2008 JDM EVOX, Mode23 USA EVOX etc. in order for it to work properly?
or can we just leave the drop box at Evo X... because i never did the mode23 even though there is a beautiful illustarated how to
I'm pretty sure you are still stuck with the regular Evo X "CAN" requests if you don't have your ECU flashed with the Mode23 changes.
Step by step guide is here and well worth it:
https://www.evolutionm.net/forums/ev...lustrated.html
