08+ RRM side mount plate kit
Thanks,
i was wondering how it stayed on also. the license plate is held on by them to i think. im trying to find out what size holes to drill, i was thinking about just sizing it up with the ones that are on the middle bumper.
What can you use to cover the holes up or will vinyl be good without anything under it?
I used 1/2 inch drill bit. I looks kind of big at first, but it fits perfectly. Check before drilling anything. I used some vinyl to cover holes in the middle and sprayed with Plasti-Dip on top.
Regarding mounting grommet, here is my quick sketch
What size rivets did you use...? What material rivet did you use...? Was it a CRES (corrosion resistant steel) Blind Protruding Head Rivet...?
Off subject...
STEP 1: hold the plate holder up to the car in the desired location
STEP 2: drill 4 holes in the bumper of you car the same size as the hole in the plate holder
STEP 3: place the rubber grommets in the holes that you just drilled
STEP 4: place the plate holder back in place and fasten with the screws and washers provided.
This was meant to get tips for the installation of the kit from RRM...
