Can anyone provide instructions to correctly install the RRM Licence Side Mount Plate Kit...?
I covered the bumper with masking tape (not whole bumper
), then found a perfect position for license mount and marked drill holes with pencil. Drilled holes, took of masking tape and mounted the kit.
), then found a perfect position for license mount and marked drill holes with pencil. Drilled holes, took of masking tape and mounted the kit.Quote:
The fastener grommets that are supplied with the kit, how are they perminately fastened to the bumper...? And what size hole do you drill for these grommet fasteners...? Are they a expandable grommet...? Please explain...Originally Posted by Liuc
Thanks,
i was wondering how it stayed on also. the license plate is held on by them to i think. im trying to find out what size holes to drill, i was thinking about just sizing it up with the ones that are on the middle bumper.
What can you use to cover the holes up or will vinyl be good without anything under it?
I used 1/2 inch drill bit. I looks kind of big at first, but it fits perfectly. Check before drilling anything. I used some vinyl to cover holes in the middle and sprayed with Plasti-Dip on top.
Regarding mounting grommet, here is my quick sketch
i didnt even use those. they seemed a little cheesy... i put in rivets in the four holes. it worked a lot better. its sturdy, and looks amazing!
Quote:
What size rivets did you use...? What material rivet did you use...? Was it a CRES (corrosion resistant steel) Blind Protruding Head Rivet...?Originally Posted by 09GTSCuban
i've seen pictures of this rrm plate mount and it doesn't match up at all. i just fiberglassed my own, it's not hard you know.
Quote:
I already have the kit Originally Posted by lancerarmstrong
This was meant to get tips for the installation of the kit from RRM...????????????????????????????
Quote:
Bump...Originally Posted by JoeyBallGame
STEP 1: hold the plate holder up to the car in the desired location
STEP 2: drill 4 holes in the bumper of you car the same size as the hole in the plate holder
STEP 3: place the rubber grommets in the holes that you just drilled
STEP 4: place the plate holder back in place and fasten with the screws and washers provided.
Those aren't good instructions we need specs. and sizes maybe even a tutorial video if you'd be so nice..
I've been told to place the license side plate one and a half finger away from the middle part. like the end of the grille
