P0135 fix
Old Aug 29, 2009 | 07:58 PM
honki24's Avatar
P0135 fix
I need one. I'm using a WB as my front 02 sensor and I need to kill the P0135. Is there a periphery bit to shut off? If not, what is the resistor value I need to use on the plug and between what pins? I read in another thread that FAA bit 14 would kill it but that's untrue. I have the 94170014 '03 EVO 8 Rom.
Old Aug 31, 2009 | 12:16 PM
honki24's Avatar
puh-lease.
Old Sep 20, 2009 | 06:42 PM
honki24's Avatar
Neither FCA bit 6 nor FCA bit 3 do it either. Apparently there's no way to kill the front O2 heater CEL. I'll just have to put a resistor in. I think I'm reading that a 75Ohm 10 W ought to do. I just ordered a mil spec 75Ohm 10W from ebay. Hopefully that will be cooler than the current 200+F O2 sensor zip tied to my engine.
Old Sep 21, 2009 | 12:43 AM
evonut270's Avatar
go into "ECU_perephery" the code should read 56DA change the code to 16D0 this will disable the front 02 heater.
Old Sep 22, 2009 | 12:09 AM
JRR's Avatar
JRR
where would i find this?
ive been trying to get rid of that pesky code for a year now!
josh
Old Sep 22, 2009 | 02:39 PM
evonut270's Avatar
when you open a rom you have your menu down the left hand side.find the "ECU perephery" section find the line that says "ecu perephery" open it and change the code to 16D0
Old Sep 22, 2009 | 03:51 PM
JRR's Avatar
JRR
and thats when im actually pulling the rom from the ecu, not when i open it on my computer for editing correct?
josh
Old Sep 22, 2009 | 04:54 PM
evonut270's Avatar
josh
you can do it either way.if you want to pull the rom open it and change the code then flash back.
Old Sep 23, 2009 | 07:12 AM
JRR's Avatar
JRR
can you post a pic of where it is. for some reason i can not find it. i wonder if it has something to do with the oz rally/evo ecu thing again?
dont have my 8 ecu yet but will be soon, but if ican get rid of that pesky code then ill be happy!
josh
Old Sep 23, 2009 | 02:00 PM
evonut270's Avatar
post your rom up and ill do it for you.
Old Sep 25, 2009 | 06:19 PM
rdtech's Avatar
Such a good guy!
Old Sep 25, 2009 | 09:26 PM
JRR's Avatar
JRR
its too large of a file even zipped. got an email i can send it to?
josh
Old Sep 26, 2009 | 09:30 AM
evonut270's Avatar
josh
evonut270@hotmail.com
Old Sep 27, 2009 | 04:56 PM
JRR's Avatar
JRR
email sent
Old Sep 27, 2009 | 11:12 PM
evonut270's Avatar
email sent
what evo do you have? send me your XML file.
