Major problem with my log *Please Help*
Old Sep 15, 2009 | 08:40 AM
xLaNcErEvOx's Avatar
Went out to do my first log with EvoScan and came across an issue. This is on the factory timing/fuel maps. When on WOT I have TPS, Knock and probably other issues. Heres my TPS and I attached the excel log also. PM me please.
TPS
21.17647059
21.56862745
21.96078431
62.74509804
100
100
64.31372549
100
100
24.31372549
90.19607843
100
100
100
61.56862745
100
100
80.39215686
80.78431373
67.05882353
94.11764706
96.47058824
71.76470588
50.19607843
69.80392157
78.03921569
70.58823529
85.09803922
55.68627451
61.17647059
73.7254902
45.49019608
60.39215686
64.31372549
71.76470588
76.07843137
80.78431373
91.37254902
65.09803922
92.54901961
52.15686275
60.39215686
92.54901961
33.7254902
Old Sep 15, 2009 | 08:50 AM
I know for sure its knocking because I feel the car pull timing about 3 times throughout the run
Old Sep 15, 2009 | 09:13 AM
G20's Avatar
G20
your log doesn't look right. what is your evoscan settings?
Old Sep 15, 2009 | 09:21 AM
what settings? and could this be caused by a low octane? i let someone else drive my car and they might have filled it up with something other than 93oct.
Old Sep 15, 2009 | 11:22 AM
logic's Avatar
TPS is bouncing all over the place. Was your foot planted during that pull? Absolutely no lifting? The latter part of your log (4000 RPM to redline) has the look of someone fluttering the pedal a bit. Ask a friend to watch your foot during a pull. Yes, I'm serious.
As for knock: you're logging knock voltage rather than knock sum; scroll down in EvoScan, uncheck "Knock Voltage", and check "Knock Sum" instead. That'll give you the values you're expecting.
Edit: as for cause? Could be any number of things, and I've seen knock on the stock maps before. It could certainly be a batch of bad gas; you could toss a can of toluene or xylene (from the hardware store; in the paint aisle, typically) in the tank to see if that helps, if you just want a cheap octane boost until your next fill-up. If you're sure it's good fuel, you might consider pulling timing a bit in the ranges you're seeing recorded knock.
Old Sep 15, 2009 | 12:20 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
restart your laptop and make sure the usb cable is plugged in before you fire up evo scan...
Do a datalog and check it before you go out and waste your time.... Mine did that a few times and I was like **** have to do it again...
I'm running Mitsulogger
Old Sep 15, 2009 | 12:40 PM
im 100% sure my foot is planted and it is recording knocksum but ill go do another test run:
KnockSum
13
12
11
10
13
19
18
17
18
23
22
20
19
25
24
24
Old Sep 15, 2009 | 01:51 PM
EVOIXreno's Avatar
check your TPS Sensor
Old Sep 16, 2009 | 02:07 PM
the most recent thing i added were spark plugs. if they mis-fired would it cause the tps to go crazy? and when i was driving earlier this morning i hit a bump and for a few seconds the throttle didnt work either... any ideas?
Old Sep 18, 2009 | 01:29 PM
dxbtune's Avatar
Pop your bonnet and check your tps its on the throttle body on the firewall side. The retaining clip night not be there or the plastic is cracked (loose fit)
