Cobb Stage 2 map stronger than Perrin Stage 3????
Old Nov 3, 2009 | 06:52 PM
jasonsrt4's Avatar
We'll as the topic states, I have Cobb 1 and 2 plus perrin stage 3 loaded. I tried them all tonight, and without a doubt Cobb stage 2 pulls harder the the Perrin 3 map. I even did the little dyno thing on the same stretch of road several times. Cobb always came up with more power. I did each one three times. no knock count to speak of. Any thoughts?
08 evo x, front mount, turbo back,
Old Nov 3, 2009 | 07:59 PM
dcpatters's Avatar
You'd have to check the map itself; load timing, boost, MIVEC, etc. What mods do you have for these maps?
Old Nov 3, 2009 | 08:13 PM
jasonsrt4's Avatar
I have everything it stipulates for the perrin. Intercooler, tbe, stock intake with drop in, and 93 oct. I thought there was supposed to have about 30 hp difference between the two.
Old Nov 3, 2009 | 08:49 PM
tephra's Avatar
could be anything... upload a log (rpm/timing/boost/afr if u got it)
Old Nov 4, 2009 | 01:07 PM
jasonsrt4's Avatar
I will go do some 3rd gear logs tonight and post them both up. Thanks!
Old Nov 4, 2009 | 01:55 PM
UT_EvoX's Avatar
Could be a number of things, but we'd have to see corresponding data logs to say for sure.
But I'm thinking more aggressive timing on the Perrin map causing lower timing overall because of knock pull. Or possibly overshooting the load target tables with too much WGDC and having the ECU drop the WGGC way down at the onset of full boost to compensate.
Old Nov 4, 2009 | 03:42 PM
jasonsrt4's Avatar
Ok I could only get second gear logs due to traffic. But I have one of each in the p3 and the c2. Now how do I post these?
Old Nov 4, 2009 | 04:01 PM
jasonsrt4's Avatar
Cobb map
Perrin map
