FS: Rebuilt 5-Speed Trans w/ 6speed conversion
For sale is a Evo 8 5 speed transmission with the conversion parts needed to change a 6-speed car into a 5-speed.
The transmission has been completely rebuilt and will work better than a new factory trans.
The parts replaced were as follows
- 1st through reverse updated synchronizers
- All Shift sleeves
- 3rd/4th shift fork. The other two were in perfect shape
- All oil seals
- Input shaft bearings
- New 4th and 3rd gear on input shaft
The syncro’s installed were the updated bronze syncro’s, which will last longer than the factory provided brass syncro’s.
All the gears in the transmission, other than 4th and 3rd gear, were in like new condition and did not have any wear to them.
The transmission has also been properly shimmed and adjusted for minimal play.
Finally, the transmission casing has been glass beaded, giving it a look better than new.
The 6-speed to 5-speed conversion includes the following
- shifter base with shifter
- shifter cables
- drivers side transmission mount
- speed sensor
- reverse switch
- reverse switch wiring harness.
- shifter cable bracket
It is missing the following
- Shift knob
SOLD!
http://i226.photobucket.com/albums/d...isf/trans1.jpg
- All Shift sleeves
- All oil seals
- shifter cables
- speed sensor
- reverse switch
- Shift knob
SOLD!
