AccessPORT EVOX Map Explosion!
Old Dec 16, 2009 | 12:03 PM
COBB Tuning's Avatar
COBB Tuning is pleased to announce another major roll-out of new Off-The-Shelf (OTS) maps for the 2008 Mitsubishi EVO X. Now, every performance map is available with an optional low wastegate duty cycle (LWDC) designed for cars currently suffering from overboost issues. These new maps lower the duty cycle controlling the wastegate, increasing the volume of exhaust gasses that bypass the turbine, reducing turbo shaft speed and the resulting boost levels.
This latest release doubles the number of maps available for the EVO X, bringing the total number of maps to over 120 each for the GSR and MR models. These new maps will make it even easier for EVO X enthusiasts to find an Off-The-Shelf map that optimizes their cars' modifications and its response. COBB Tuning's continued dedication to providing the ultimate tuning solution for the EVO X has resulted in the world's largest Off-The-Shelf map database.
Stay tuned for additional exciting news regarding the COBB Tuning AccessPORT and the Mitsubishi EVO X. We're not done yet!
Old Dec 16, 2009 | 12:38 PM
userwave's Avatar
big thumbs up to cobb!
Old Dec 16, 2009 | 12:41 PM
mmartahus's Avatar
i cant wait to get an AP
Old Dec 16, 2009 | 12:50 PM
AJ PwR's Avatar
You guys are the best !
Old Dec 16, 2009 | 04:00 PM
GetterDragun's Avatar
Cool! I can't wait for the AccessPort to be available for my Evo X.
Old Dec 16, 2009 | 04:39 PM
DB20PSI's Avatar
What are the symptoms of the "overboost" condition? Is this recommended on a stock MR in a cold weather climate?
My AP came to my house on Monday - would it have these maps loaded?
Thanks
Old Dec 17, 2009 | 11:33 AM
mrMTB's Avatar
Cobb, any chance of also releasing 1000cc injector maps to complement the 800cc maps? From what I've seen, e85 on 800cc injectors does not leave a lot of headroom...
Old Dec 17, 2009 | 01:12 PM
alex3dworld's Avatar
why some cars are "overboosting" and others not with the same maps.
i have seing sometimes my boost gauge reach 28 pounds, but i'm not sure if it's the gauge or i belong to the overboosted cars??
any help
Old Dec 18, 2009 | 11:11 AM
Overboost would be a car that is hitting very high boost numbers, 2-3lbs beyond what the target in the map calls for. Look at the map notes and you can see the boost levels we are targeting. We believe this is due to the fact that not all EVOX have the same boost control system, or rather, a system that is calibrated differently from car to car. Some cars need the restrictor pill mod, some don't.
1. So, our revised advice is to install the normal map and run it. If you hit the boost targets without going too far over, you do not need to alter the restrictor.
2. If you don't hit your boost targets, remove the pill.
3. If you run the with the pill installed and you overboost, run the lower wastegate duty cycle map.
Old Dec 21, 2009 | 11:46 AM
i'm running the stage 2 +SF 93 octane. per your instructions i removed the pill before apply the map. the target of the map was 25 lbs right?
my boost gauge
http://prosportgauges.com/amber-whit...t-gauge-1.aspx
is giving me 28 peak, should i try putting the pill back first and see the resoults?
i try the LWDC map allready and is giving me 20 ish, less than 25 peak,
if i datalog my car can i send you the map so you can tell me what is the best option?
Old Dec 21, 2009 | 01:06 PM
duracraft's Avatar
Still waiting for the release of the 2010 EVO X AP.
Old Dec 27, 2009 | 12:07 PM
crimson49er's Avatar
me too
Old Dec 27, 2009 | 07:13 PM
fmax420's Avatar
I would also like to see the 1000cc injector maps. I don't want to waste money on the 800cc.
Old Dec 28, 2009 | 01:51 AM
seeevo's Avatar
so what are the consequences for overboosting (2-3 psi over) ? do you have just loss of power or is it very dangerous for your car?
Old Dec 28, 2009 | 05:03 AM
raytrix's Avatar
The value of the AP in the used market has just went up another $25 haha, this is like the stock market. Each time Cobb updates with more support the less it's being sold used and more new is circulating.
