Sponsored by:
Sponsored by: CARiD
10,000mile maintenance!!
Old Apr 23, 2010 | 06:09 PM
jrsimon27's Avatar
So i took my car to a car service shop had the engine oil change checked the levels on all the car and had them rotate my tires(first time) to my surprise the front tires inner threads where worned out they put the car on the aligment elevator and everything seemed to be normal so the guy told me that maybe it was cause i didnt rotate my tires at the 5,000mile mark!
so what do you guys think??
cant be normal!
Old Apr 23, 2010 | 06:20 PM
nrgizeman's Avatar
hmmm... i have the same issue. front tires have severe camber wear. rotated mine at 10k miles. i should have done it at 5k... dang it!!!
Old Apr 23, 2010 | 06:41 PM
xtmx's Avatar
Its normal, mine were gone at 6000.
Old Apr 23, 2010 | 06:46 PM
droppinbottom's Avatar
I rotate my tires every 4k at the same time I change the oil. My stock tires lasted a little over 12.5k and I attribute the wear to my suspension setteling after I alligned the car.
Old Apr 23, 2010 | 08:49 PM
Marker55's Avatar
The service manager recommended I rotate mine every oil change which is every 5,000mi, I guess Ill do it when it comes time, thought maybe he was just tryin to make a buck
Old Apr 23, 2010 | 09:03 PM
buchnerj's Avatar
Crazy camber wear is normal for the Evo platform. The advans are very soft and wear out fast, and with our car coming with an alignment favoring the inner edge they wear even faster. It is a common problem with VIII, IX and X.
Old Apr 23, 2010 | 09:09 PM
Ltdanish07's Avatar
I replaced my stock advans at 11k. Inner side was worn. The tires are soft and if you drive the car like its supposed to be driven they wont last long. I ended up getting myself a set of bridgestone re960s. Did really well in the snow and still grip really well.
Old Apr 23, 2010 | 09:46 PM
supergengo's Avatar
I rotate every oil change... 3.5k to 4.5k miles.
Old Apr 23, 2010 | 09:57 PM
bremboy's Avatar
Yeah my Advans are long gone.
Old Apr 23, 2010 | 10:31 PM
tipoytm's Avatar
same problem with me. i shud had them rotated them 5k miles ago. at 10k now and they worn out.
Old Apr 23, 2010 | 10:53 PM
jrsimon27's Avatar
so is this normal??
will rotating them every 5000miles avoid this???
Old Apr 23, 2010 | 11:25 PM
sbkimm's Avatar
Originally Posted by jrsimon27
so is this normal??
it will not avoid this, it will just slow down the process a little bit. this is inevitable... especially if you do any aggressive turns
Old Apr 24, 2010 | 01:27 PM
Finest's Avatar
My Advans lasted about 20k miles with regular rotations, how hard are you driving the car everyday?
Old Apr 24, 2010 | 01:34 PM
jrsimon27's Avatar
just daily drive it and sometimes do spirited driving but not much!
Old Apr 24, 2010 | 02:09 PM
boondoc's Avatar
Like everyone said this is normal wear. Its even like that on my RA so you shouldn't have to worry.
