Sponsored by:
Sponsored by: CARiD
Aem Wideband UEGO Communicating with ECU?
Old Nov 14, 2012 | 06:18 PM
HDGamer's Avatar
I just called my tuner and was told that there is a way to connect the standard AEM UEGO wideband to the ECU, and program it so that when the wideband reads LEAN, to have the ECU work magic to save the engine. Is this true? I've never heard of any such way to do this outside of using the new gauge from AEM, the failsafe one.
Old Nov 14, 2012 | 07:37 PM
evo8426's Avatar
You can with the Evo 8/9 but I'm not too sure about wiring it into the ECU for the X. Did your tuner specify that it was possible with the X?
Old Nov 14, 2012 | 10:19 PM
HDGamer's Avatar
Ahhh that must be it.
Old Nov 15, 2012 | 01:41 AM
armysoldier1073's Avatar
With the uego to log in an x... First the rear o2 needs to be disconnected. Then the yellow wire ( unused from initial install) needs to spliced into the YELLOW wire that comes from the harness the rear o2 is connected to (under passenger seat). Then in evoscan a new value needs to be created so the ecu reads it. Your making the ecu think it is still using the rear o2 but your actually using the WB. I'll look for the how to.....
Old Nov 15, 2012 | 01:52 AM
http://www.evoxforums.com/forums/showthread.php?t=18511
discodino
Feb 22, 2017 03:01 PM
Kustom09art
Aug 4, 2015 07:38 AM
franc01
Apr 12, 2015 06:24 AM
PATRICK B.
Mar 11, 2015 01:51 PM
Mr. Evo X
Oct 18, 2013 11:53 AM
