Sponsored by:
Sponsored by: CARiD
DEI Radiator Relief Additive
Old Dec 29, 2012 | 11:46 AM
Noe18's Avatar
http://www.maperformance.com/dei-rad...l#.UN9H847Bodk
anyone has tried this and does it work?
Old Dec 29, 2012 | 11:49 AM
jdmEviL8's Avatar
probably works as good as octane booster for fuel...
Old Dec 29, 2012 | 11:53 AM
mirkendargen's Avatar
Sounds like BS from the description. Heating up faster means it decreases the specific heat. Cooling better means it increases the specific heat. It can't do both...
Old Dec 29, 2012 | 12:04 PM
Noe18's Avatar
I know that when i change to redline cocktail tranny fluid it does heat up quicker. I was looking into something to cool down the engine.
http://www.maperformance.com/mishimo...l#.UN9LuI7Bodk
http://www.maperformance.com/mishimo...l#.UN9L5o7Bodk
Old Dec 29, 2012 | 08:17 PM
Johnr352's Avatar
[/url]
Are you saying that your changing to the Redline cocktail in your transmission has caused your motor's coolant to heat up more quickly? I think that's rather unlikely, as the fluids don't interact and the transmission heats up through use, not as a result of the motor getting warm. This is to say, you could idle your car in traffic and overheat and your transmission fluid could be relatively cold. Maybe I got that wrong though, and don't understand..
A thermostat won't really cool your motor down either, as it simply opens at a lower temperature. So, while there might be an immediate benefit from opening at a lower temp, it's short lived as the thermostat is out of play once the car is warmed up.
A bigger radiator can, of course, keep coolant temps lower. I didn't
T think the Evo needed too much help in this area though and I'm curious to learn other's results. We've found that, even under racing conditions the Evo X coolant stays pretty cool. Even before our oil management solutions, when we saw oil temps at 285+ the water was just right.
Old Dec 29, 2012 | 08:21 PM
Johnr352's Avatar
Weird, I wonder if this is something like Water Wetter, which does work wonderfully, while wildly well priced.
OakosAutomotive
EvoX 'For Sale' Engine Internals and Drivetrain
129
Jan 29, 2020 06:16 AM
OakosAutomotive
227
Aug 13, 2019 01:00 PM
guyver858
10
Aug 15, 2015 05:59 PM
RallySport Direct
EvoX 'For Sale' Miscellaneous
Aug 26, 2014 08:59 AM
