TC-SST issue
Old Aug 8, 2012 | 07:58 AM
korzunm's Avatar
TC-SST issue
Hello community
My friend have a strange case with TC-SST
Strange noise on start
Here is the video
and
Oil and filter was changed a couple days ago.
TCU was reflashed after this case start.
Nothing didn't help, any ideas?
Old Aug 9, 2012 | 06:53 AM
didz's Avatar
thats wot mine sounded like on start up,had mine reflashed by dealer. was ok till i went on 140 mile drive.then gearbox started playing up losing gears.its in the dealers having a new gearbox fitted. ive owned the car for 2 months,driven it for 2 weeks and been in the dealers the rest of the time.
Old Aug 9, 2012 | 07:36 AM
lousEVOxmr's Avatar
wow, how many clanks do you hear when its starts , do you hear one clank and then the zipp? or zip the clunck??
Old Aug 9, 2012 | 07:45 AM
korzunm's Avatar
normal its clunck - clunck
this one make clunck - dzzzz
Old Aug 9, 2012 | 09:17 AM
Widoww's Avatar
Wow that's not normal
I'd get it looked at before something break
Old Aug 9, 2012 | 01:02 PM
resident's Avatar
Hello! we are talking about my EvoX.
yes, it is make clunck - dzzzz.
But very strange thing that this sound comes only on the first engine start after the car was parked for some long time. Here is the video of second start immediately after the first
as you see, there is normal clunck - clunck.
And in general the SST works perfectly, the gears shifting is very clear.
I dont know what to do with this sound... maybe it is not the gearbox issue
at mitsubishi service they also dont know what makes this sound.
Old Aug 9, 2012 | 01:07 PM
Optiblue's Avatar
Holy smokes, that is not normal. Are you sure you put the right type and amount of fluid in?
Old Aug 9, 2012 | 01:33 PM
resident's Avatar
yes, the fluid and amount of it are correct. In Europe fluid named - CASTROL TRANSMAX DUAL
the same fluid is used by all Evoclub Ukraine and everything is ok.
I made some investigations and I'm starting to believe that this sound cames not from SST..... and I realy hope that it is true
Old Aug 9, 2012 | 01:46 PM
deez_nutz's Avatar
sounds amazing
Old Aug 9, 2012 | 03:33 PM
gaabbee's Avatar
Its not the sst. The starter motor is getting hung up on the flywheel. I'm pretty sure there's a lubrication problem after it sits for a while that doesn't let the gear release and there fore the grind.
Old Aug 9, 2012 | 03:43 PM
richardjh's Avatar
So the starter is being spun up bigtime after the engine has started, then finally disengages with a grind noise?
I've had this sound occur two times in my two years of RA ownership.
Now... the $64,000 question... has anyone with a 5MT Evolution X ever had this exact same noise? That's be very illuminating indeed, wouldn't it?
Rich
Old Aug 9, 2012 | 07:16 PM
gaabbee's Avatar
Rich
yep, im pretty sure this also has to do with the slight bump forward sometimes on start up. Think about taking a gear set apart slowly while its spinning...it will skip the teeth of the gears against each other making a grinding noise...similar to grinding gears on a manual transmission. I have not seen any gsr's with this problem, as they might have a different starter motor/flywheel.
Old Aug 10, 2012 | 11:19 PM
resident's Avatar
Yesterday I was at service. We have removed the starter and then cleaned and lubricated it. The teeth on starter and flywheel are in very good condition. I made a photo
and here is the video of starter's work. it is working good.
and, unfortunately it is not helped. the sound on cold start is still present
what else it can be
can it be a timing chain issue???
Old Aug 11, 2012 | 10:13 AM
gaabbee's Avatar
You will not be able to see any marks. The duration of the noise is not that long so there's not much damage. Pretty sure its not a timing chain noise.
Old Aug 16, 2012 | 02:04 AM
resident's Avatar
Today I have visited mitsubishi dealer again to check if everything is ok with timing chain. They have removed the valves cover and didnt find any problems with timing chain or tensioner. So, that sound on cold engine start is not timing chain issue.
I was trying to make some good photo but without succes.
We also re-checked the starter and now we are sure that it is not starter issue.
At the moment we have cool weather (15 degrees Celsius) and the bad sound heard after two hours of parking. So I decided to leave the car at the dealer, to determine which unit issues this sound.
I really hope that this sound is not SST issue.
