Mr sst upgrades underway
Thank you guys for all the support!!!
Here is an UPDATE:
The guys over at SSPerformance are knee deep into my car. The intake manifold has been pulled and sent off to MAperformance for development.
Up till last night, this is as far as they got with pulling the SST out:
They said, "non serviceable my @ss" They are telling me, that any good tuner shop can do pull the SST and install the parts they will be producing.
As always, I will keep everyone posted. While they are developing these new parts, they also wanted me to ask the community about what other parts you guys want to see developed. So by all means; what do you guys want to see developed for the X?
Here is an UPDATE:
Upgraded oil cooler, transmission temp sensor tap, better transmission cooling ducts (straight from bumper to cooler) , air intake ducting to larger funnel from front bumper (direct pipe from front grill to intake ducting mounted to body under hood)... think that's all I can think of..
Even people who are not interested in significantly increasing torque capacity still have problems in stock form with the transmission overheating. A circulated & radiated transmission fluid cooling solution, maybe even with a larger fluid capacity, would be required for anything that needs upgraded clutch packs, but would also be attractive to owners with less ambitious performance goals. Doubly so if it'd be compatible with both the factory transmission and the upgraded clutch pack setup, so people could upgrade in phases as needed. The bottom line is if they can get something that'll let people run more laps around a road course in S-Sport mode without going into limp mode, people will buy it.
It seems that the ECU interface to the transmission hasn't been researched too much, so anything in that arena would be welcome
This might be overly ambitious, but what about a revision to the launch control system? From the sounds of it, a lot of people are also less than satisfied with low-speed/from-a-stop gear engagements in normal and sport mode during daily driving.
This might be overly ambitious, but what about a revision to the launch control system? From the sounds of it, a lot of people are also less than satisfied with low-speed/from-a-stop gear engagements in normal and sport mode during daily driving.I agree with the comment on the ECU/TCU.. It would be nice to see a RalliArt TCU with the MR's super sport mode, and launch control program.
