Blitz SST cooler kit
Old May 30, 2009 | 09:18 PM
LVSBB6's Avatar
Good news for SST owners :
http://www.blitz.co.jp/products/cool.../atfcooler.htm
Old May 31, 2009 | 12:06 PM
WiCkEd-FaSt's Avatar
Awesome find! Another option for us SST owners, although i haven't once overheated my tranny nor had I had any warnings about the tranny at all and I drive aggresively
Old May 31, 2009 | 10:14 PM
smgevo's Avatar
Where do they suggest mounting it? A replacement for the stock cooler? Mount in front of the stock cooler (will block some flow to the stock cooler)? Mount in front of the oil cooler at an angle on the other side (remove fog lights), or mount in upper opening of front facia (blocking top side of radiator?
Old Jun 1, 2009 | 10:43 AM
blk-majik's Avatar
Anyone care to translate what any of that says?
Old Jun 1, 2009 | 12:34 PM
mrMTB's Avatar
You won't overheat your transmission unless you're doing very aggressive driving with the selector in S-Sport. I did a couple sessions at the track in Sport mode and had no issues. Ten minutes into my session in S-Sport, I hit the "Slow Down" screen...
Old Jun 1, 2009 | 06:47 PM
Red Dragon's Avatar
More info?
Old Jun 1, 2009 | 07:50 PM
LVSBB6's Avatar
Babelfish translation:
1. Standard adopting the drawn cup type core. (Only SST cooler for run sir evolution X, adoption side tank type core)
2. Actualizing high reliability with the fitting of new development.
3. The fitting of BLUE+SILVER is superior even in fashion characteristic.
4. As for the SST cooler for run sir evolution X, the twin core specification which jointly uses the genuine SST cooler. The private air guide it belongs, it leads the travelling wind which is adopted to two cores without wastefulness.
*In order to prevent the temperature rise of the ATF where the coordinating point is lower than the motor oil, adopting the core of drawn cup type. In the vehicle which is tuned, it becomes easy to be connected to the temperature rise of the ATF, the slippage of the result clutch and the damage with the speed change malfunction and the oil film being cut off easy to occur. In addition, the thin inner fin (offset type) you adopt for the tube of the core, take heat securely from the ATF, you show the cooling efficiency which is superior. Furthermore the vivid blue of new development and the fitting of the silver were adopted, high reliability and preeminent fashion characteristic were actualized. * The SST cooler kit for run sir evolution X has adopted the side tank type core. In addition, it becomes the twin core specification which jointly uses the genuine SST cooler.*
Everyone should understand by now? lol
Old Jun 1, 2009 | 11:24 PM
gunzo's Avatar
Standard air cooled cooler
It runs as a twin oil cooler design using designed airducts (note not useable with foglights)
Old Jun 3, 2009 | 05:06 PM
MACH3EVO's Avatar
as the previous post this runs as a dual core setup.
Meaning- that the facotry core runs as a secondry setup
the Blitz unit is the primary
Instaltion requires removal of fog lamp assembly
Old Jun 3, 2009 | 09:47 PM
LVSBB6's Avatar
do you guys think adding a fan to the stock cooler would be more or less effective compared to this?
Old Jun 6, 2009 | 07:12 AM
MACH3EVO's Avatar
adding a fan is apreety cheap way to do things but really you are doing a 1/2 *** job, put the right gear in first time
Old Jun 6, 2009 | 08:13 AM
LVSBB6's Avatar
Found a picture of how the Blitz SST cooler is mounted:
Old Jun 8, 2009 | 10:52 PM
pcasupreme's Avatar
i wonder which one is better, this one or the ssp one..
Old Jun 9, 2009 | 09:02 PM
weebles's Avatar
When is this available / how do I buy it?
Old Jun 9, 2009 | 09:53 PM
evox44's Avatar
How much HP can this handle? The SSP+clutch pack is rated at 550whp or so?
