View Poll Results: What would you use if you had the choice for your TC-SST?
Voters: 30. You may not vote on this poll
TC-SST Fluid Poll
I would stick to the OEM stuff because you need that thin ATF like fluid in order for the clutches to operate properly. If you use thicker fluids, the clutches will slip more especially in cold temperatures increasing wear and reducing their lifespan, more slippage = more heat.
The willall is specifically made for the wet clutch trans. It is alledgedly better than the oem fluid. Its ability to facilitate clutch grip is claimed to be significantly better than the oem fluid. Everyone should probably read the threads and do some research before voting....
The willal is specifically made for the wet clutch trans. It is alledgedly better than the oem fluid. Its ability to facilitate clutch grip is claimed to be significantly better than the oem fluid. Everyone should probably read the threads and do some research before voting....
ADJECTIVE:
Represented as existing or as being as described but not so proved; supposed.
I think I mispelled, but I used the word intentionally. The reason for using it is that though I have no reason to doubt Willall (and I don't), I could not find any independant verification, with supporting numbers of their data.
Here is a link to there site: http://www.willallracing.com.au/lubricants.htm
Link to definition of word, corrected for spelling: http://education.yahoo.com/reference.../entry/alleged
Doug@WGP
Mar 28, 2011 11:40 AM
Tray@Forged
Evo X Dyno Results
Feb 16, 2011 09:56 AM
