Cooling nozzles on the SST fluid cooler?
Old Sep 16, 2010 | 09:38 AM
migs647's Avatar
I just had an idea (might be too far fetched, but thought I'd share anyways).
On my Evo VIII I had fmic cooling nozzles. It had auto and manual that sprayed a fan of water onto the fmic depending on the input temperature (for auto).
I wonder if we can adapt these same systems to spray the SST cooler during a tracking session. After all water can disperse heat much quicker than air.
It would be ideal to have the nozzle system reading the temp and spray it accordingly automatically. I wonder if it's possible to adapt one of these cooling systems from the older Evo to this setup.
What do you guys think?
Old Sep 16, 2010 | 04:06 PM
skiracer's Avatar
JDM Evo's have the intercooler sprayer system as OEM i believe. Not sure if their is code in the USDM ECU that can control it though.
Old Sep 17, 2010 | 09:23 PM
migs647's Avatar
There is code in the USDM ECU to control the intercooler sprayers, but I want to convert those sprayers to the SST transmission cooler so those get cooled instead. Would be cool and slick.
Old Sep 18, 2010 | 10:57 AM
bojassem's Avatar
Hmm. Not a bad idea, I would suggest you to build an beta model and keep the copyrights for yourself
Old Sep 18, 2010 | 11:22 AM
skiracer's Avatar
You can probably just buy the OEM intercooler sprayer button, run some lines for the sprayer and it "should" work then
Old Sep 18, 2010 | 11:26 AM
migs647's Avatar
Yah... I think I may try this.
Before I do anymore mods, I want to get a temp gauge on the tranny so i can monitor it though.
The good thing is, with this mod, there wouldn't be any modifying the transmission! No way to void your warranty this way.
Old Sep 19, 2010 | 01:48 AM
lousEVOxmr's Avatar
ya if your heat sensor runs on your cooler line , and your cooler has 2 windshield washer nozzels atached to it ... it should work ... ( i.e scrap hard for a WW pump and 2 nozzels from some civic lol )
LCS
Feb 24, 2016 01:35 PM
Donkeypunch
Dec 2, 2008 06:43 AM
evo_iv
Apr 24, 2008 01:46 AM
CombatCQB
May 3, 2004 02:34 PM
Changy
Sep 24, 2003 09:48 PM
