View Poll Results: Have you had to have your transmission replaced?
Yes: unmodified / regular driving
5.56%
No: unmodified / regular driving
10
18.52%
Yes: modified / regular driving
5.56%
No: modified / regular driving
22
40.74%
Yes: stock / autocross-track days
0%
No: stock / autocross-track days
5.56%
Yes: modified /autocross-track days
0%
No: modified / autocross track days
9.26%
I have a GSR and just wanted to see what this is about.
14.81%
Voters: 54. You may not vote on this poll
SST Owner Poll
I'm trying to get a more accurate idea of how many SST owners have actually had a transmission problem. Hopefully this will help to clarify things.
Also please post:
Year: model year
Mileage: current mileage if no problems or that mileage when problem was noticed
Mods: if any
Driving type: daily only, drag, autox, track days
Type of problem (if any):
Did warrany cover it?:
Also please post:
Year: model year
Mods: if any
2010 MR.
9200 miles of fairly aggressive, mostly city miles. During the summer months the car was launched at least several times a week with no problems.
Only mods are a Cobb stage 1 OTS map/HKS drop in.
Year: 2010 USDM MR-Touring
Mileage: 30,000
Mods: TBE, E85, DW100 inj, BlaqOps single fuel Pump, AP, Pro tune , WillAll fluid.
Driving type: daily, limited drag
Type of problem (if any): P1808 (SST fluid temp sensor failure), SST replaced.
Did warrany cover it?: NO
Mileage: 30,000
Year: 2010 MRT
Mileage: 28,000 as of today km's
Mods: TBE, CAI, Tuned all boltons, fmic etc
Driving type: daily driver, 200+ 1/4 mile passes+ launches
Type of problem (if any):no problems
Did warrany cover it?: they will cover whats needed or the car goes thru showroom window
Wait so how much did it cost you to replace it?
$8,800 plus install (8 hours). I used aftermarket fluid, ECU was flashed, and TBE, all grounds for refusing to replace the SST under warantee per Mitsu. I could win this in court but I did not want my car out of service for months and I did feel a moral responsibility that the failure "might" have been my fault (aftermarket fluid)
Oh yeah they knew, Willall fluid, stopped using it in the new box just to err on side of safety. Actually the Willall did provide for a .2 sec improvement in 60' times at the drag strip (credit where credit is due) due to its heavier viscosity but I see little else to reccommend it over the OEM Diaqueen fluid.
2010 MR-T (SST)
Stock clutch packs
OEM DiaQueen SST fluid
SSP trans Deep Sump
SSP Front mount trans cooler
OEM intake w/dropin
CBRD BBX full Turbo
AMS DP
RRE Rally test pipe
MXP II CBE
DP 1000 injectors
BlaqOps single pump
WORKS tune using OP (cleaned up by Bryan)
Green relay (yeah that’s it, it MUST be a faulty fuel pump relay!)
No longer true, apparently, rather than to try meet Getrag specifications and fight Mitsu for approval they have decided to disguise its use. Both Willall and SSP now have formulations that mimic the yellow Diaqueen SSTF in color. If you are comfortable with this strategy by all means give them a try, it does seem that you are less likely to have to make a claim in the first place if you stick with the approved fluids though.
2010 MR-T (SST)
Stock clutch packs
SSP trans Deep Sump
OEM intake w/dropin
CBRD BBX full Turbo
AMS DP
RRE Rally test pipe
MXP II CBE
DP 1000 injectors
BlaqOps single pump
2010 MR-T (SST)
Stock clutch packs
SSP trans Deep Sump
OEM intake w/dropin
CBRD BBX full Turbo
AMS DP
RRE Rally test pipe
MXP II CBE
DP 1000 injectors
BlaqOps single pump
