Bung on SST to use for cooler install?
Old Jun 14, 2014 | 11:20 AM
D__'s Avatar
D__
Which bung do you use for a cooler upgrade?
I have the three bung version.
Old Jun 28, 2014 | 12:50 AM
KozmicMotorSpts's Avatar
If you have a 2008-2010 transmission, then use the plug under the clutch. (This plug is not drilled or tapped on 2011 and up). This is the method for external pump coolers.
The Dodson Sump doesn't use any of the plugs since it uses an internal heat exchanger in a billet pan to control transmission temp with engine coolant.
Old Jun 28, 2014 | 06:25 AM
D__'s Avatar
D__
I went for the bung closest to the passenger side. Thanks for the response.
evochongi
Mar 14, 2017 05:46 PM
hutch959
Jan 3, 2016 06:04 PM
hutch959
Jan 3, 2016 05:51 PM
asu11
May 10, 2012 10:27 AM
