Need Help Locating an Engine Thermo Fan Temp Switch to use with SSP Cooler
Old Jul 17, 2014 | 02:03 PM
Roen's Avatar
Hey guys,
I'm looking for a thermo fan switch to purchase that I can use in conjunction with the SSP Cooler. I've emailed a bunch of manufacturers but no one seems to have anything matching the specifications.
Temperature Range: 180*F Off
190*F On
Default Switch Mode: Open Ground
Number of Terminals: 2
Thread Size: M16 x 1.5
Bolt Size: Whatever
Preference is for a shallow bodied sensor rather than a deep bodied one.
I've attached a picture of something that's similar to what I am looking for.
The goal is to wire in this switch so that the cooler works off of temperature, instead of toggle switch only. I'll retain the toggle switch so I'll still have a master cutoff, just in case.
Any help would be appreciated!
Old Jul 17, 2014 | 09:42 PM
Roen's Avatar
Thanks to fellow user simshahh, who pointed me to the following website:
http://ecc.carquest.com/ds_fans.php?showall=yes
I've narrowed it down to the following 3:
53-13826
53-13831
53-13838
Any opinions? I'm leaning towards 53-13838.
Old Jul 17, 2014 | 10:49 PM
kozmic27's Avatar
Use that one.
Old Jul 18, 2014 | 06:02 AM
Roen's Avatar
Originally Posted by kozmic27
Use that one.
Thanks, kozmic, any reason picking that one over, let's say 13826?
Old Jul 19, 2014 | 12:19 AM
kozmic27's Avatar
A 5 degree lower off temperature that almost perfectly matches when the TCU stops full flow through the OEM cooler.
Old Jul 19, 2014 | 09:31 PM
Roen's Avatar
Cool, thanks.
Old Jul 21, 2014 | 02:53 PM
Roen's Avatar
What do you think of this switch and specs?
http://www.napaonline.com/Catalog/Ca...117_0182395977
migs647
Mitsubishi TC-SST Discussion
77
Mar 7, 2019 04:57 PM
MisterRegato
Sep 10, 2015 08:17 AM
dba Brakes
Aug 16, 2015 05:41 PM
211Ratsbud
Apr 22, 2014 01:40 PM
ayenoc
27
Dec 7, 2011 12:12 AM
