Feels like neutral?
when pushing the car, sometimes i take my foot off the gas in between shifts, just a pet peeve, however, someitmes when i shift, i go to put my foot back on the gas and it seems like the transmission doesnt catch and nothin happens.
any input? mods are intake with piping and tune thanks |
Originally Posted by 08 Evo X MR
(Post 7709665)
any input? mods are intake with piping and tune thanks How long does it stay in that neutral type stage for? Is it just for a split second then it catches, and jerks into gear? |
i normally let go of the gas, wait a sec, then give it gas again.
i havnt tried keeping my foot down on the gas to see if it catches because i was afraid of breaking something. this help? |
does your RPM go up like neutral? or just feels like it is in neutral?
Check your boost levels. Most likely a tuning issue, due to colder temps, or mod changes. The TCU has a safety feature where it releases pressure to the clutch basket when to much boost is read. IE....free rev mode. As bad as it sounds, it actually prevents you from hurting your trans.
ok i see what your sayin, and to jack, the rpm's dont move
ummmm... ok first of all in what mode are you in .??
if your in normal or even sport its normal to have a little of slipping ,
i normaly drive in sport or s sport ..... |
i drive in normal all the time but always in the manual techtronic thing. i never drive it in auto
ya when driving in TIP< put it in sport , less wear and tear on the clutch packs ....
Lifting off the throttle between shifts is unnecessary. It's like an automatic- that's how you're supposed to drive it. It's likely the computer is getting confused for a second.
Originally Posted by jsr426
(Post 7721488)
I had the Mr fell like it went into neutral from a stop... the RPM would go up like you where going to free rev'ing, then if you hold the throttle down. you can feel the clutch slowly engage then go. or you stay at a stop and the revs drop back down then you go.
eithere way annoying all then hell |
BTW iput a AP BOv on here and it made the issue worse. i tightend the spring on the BOV now it takes off great. but instead of hearing the BOV vent the air i hear what i think its called (surge) ie.. a fluttering noise from theBOV
So should you not lift up on the gas at all between shifts?
