Feels like neutral?
Old Nov 12, 2009 | 05:44 PM
08 Evo X MR's Avatar
Feels like neutral?
when pushing the car, sometimes i take my foot off the gas in between shifts, just a pet peeve, however, someitmes when i shift, i go to put my foot back on the gas and it seems like the transmission doesnt catch and nothin happens.
any input?
mods are intake with piping and tune
thanks
Old Nov 12, 2009 | 07:59 PM
jsr426's Avatar
any input?
thanks
How long does it stay in that neutral type stage for? Is it just for a split second then it catches, and jerks into gear?
Old Nov 17, 2009 | 06:55 PM
i normally let go of the gas, wait a sec, then give it gas again.
i havnt tried keeping my foot down on the gas to see if it catches because i was afraid of breaking something.
this help?
Old Nov 17, 2009 | 07:56 PM
jackygor's Avatar
does your RPM go up like neutral? or just feels like it is in neutral?
Old Nov 18, 2009 | 04:01 AM
jsr426's Avatar
Check your boost levels. Most likely a tuning issue, due to colder temps, or mod changes. The TCU has a safety feature where it releases pressure to the clutch basket when to much boost is read. IE....free rev mode. As bad as it sounds, it actually prevents you from hurting your trans.
Old Nov 18, 2009 | 08:09 PM
ok i see what your sayin, and to jack, the rpm's dont move
Old Nov 19, 2009 | 05:27 AM
lousEVOxmr's Avatar
ummmm... ok first of all in what mode are you in .??
Old Nov 19, 2009 | 05:28 AM
lousEVOxmr's Avatar
if your in normal or even sport its normal to have a little of slipping ,
i normaly drive in sport or s sport .....
Old Nov 26, 2009 | 09:59 PM
i drive in normal all the time but always in the manual techtronic thing. i never drive it in auto
Old Nov 27, 2009 | 07:04 AM
lousEVOxmr's Avatar
ya when driving in TIP< put it in sport , less wear and tear on the clutch packs ....
Old Jan 6, 2010 | 01:59 PM
Blugin's Avatar
Lifting off the throttle between shifts is unnecessary. It's like an automatic- that's how you're supposed to drive it. It's likely the computer is getting confused for a second.
Old Jul 15, 2010 | 08:40 AM
ksattic's Avatar
Do you have a reference for the above information? I am not developing much power above stock (~20whp) but I had my SST release in 1st (auto, sport) at WOT today. The revs were around 3.5k and the car went into neutral (though still said "D"), and I bounced off the rev limiter until I took my foot off the gas completely. No codes were thrown.
Old Aug 25, 2010 | 05:39 PM
sheeley91's Avatar
I had the Mr fell like it went into neutral from a stop... the RPM would go up like you where going to free rev'ing, then if you hold the throttle down. you can feel the clutch slowly engage then go. or you stay at a stop and the revs drop back down then you go.
eithere way annoying all then hell
Old Aug 25, 2010 | 05:41 PM
sheeley91's Avatar
BTW iput a AP BOv on here and it made the issue worse. i tightend the spring on the BOV now it takes off great. but instead of hearing the BOV vent the air i hear what i think its called (surge) ie.. a fluttering noise from theBOV
Old Sep 21, 2010 | 06:31 PM
joeystacoshack's Avatar
So should you not lift up on the gas at all between shifts?
