TSB 05-55-003 Heater Temp Dial Hard To Turn
Old May 17, 2009 | 01:25 PM
jrelyea828's Avatar
Alright. So instead of making a new thread. My ac works great, but when i turn my knob from cold to hot, for one, the knob'll fling back about 90 degrees. I've tried all sorts of ways to get it to switch, but my heat will not turn on. I changed my thermostat thinking that was the problem, and noticed the heater knob acting funny. As well as that, its clear that the vent is not moving from cold to hot because you cant hear it like i used to be able to. Is this pretty much in the same category as the TSB 05-55-003?
Old May 17, 2009 | 02:32 PM
0E3vobutt3r's Avatar
think you could shoot me a PM with price shipped to 21849
I've had this problem, got it "fixed" and low and behold its back. I'm going to do it this time.
thanks, nice post.
Buddy
Old May 18, 2009 | 10:47 PM
Bioxide02's Avatar
Originally Posted by mitsuorder
This is literally a 5 minute fix. The tension is really relieved a lot just by doing the gears.
Seems like it would take longer than 5 minutes! So are you saying you can just pop off the gears and put new ones on without doing anything eles listed in the TSB?
The part about discharging my AC system makes me not want to do this. But my temp dial can be a PITA, esp when passengers try to adjust it and don't know how to do it right since it binds
Old Jun 4, 2009 | 06:14 PM
[Cyanide]'s Avatar
I too would like to know this as I've been living with this problem for quite some time now. Luckily I live in an area where it doesn't really get too cold.
Old Jun 8, 2009 | 11:37 AM
mitsuorder's Avatar
Exactly what I'm saying. By replacing the gears you change the fulcrum point of the linkage therefor alleviating the binding problem.
Old Jun 8, 2009 | 01:21 PM
QwikEVO's Avatar
Russell, price shipped to 99577 please.
Thanks!
Old Jun 17, 2009 | 09:47 AM
[Cyanide]'s Avatar
Ok, I just did this on my 2003 Evo 8 and it's definitely possible to change the gears just by climbing underneath your steering wheel column.
Be warned though, it requires a fair amount of being nimble, agile & patience.
I had to squeeze myself under my steering wheel UPSIDE DOWN. Make sure you get a short (length-wise) Philips screwdriver cause if not regular length ones will hit on your steering wheel column.
But other than that, it's possible.
UNFORTUNATELY, that didn't fix my problem. My problem it turns out, is the cable that pushes & pulls the gears forwards & backwards, which is connected to the heater control knob itself.
I guess over the years & usage, the cable itself has become "loose" so to speak, whereas it should be taut.
So what happens is when you turn the heater knob one way (say to max A/C) & want to turn it back to max heat, the cable flexes and refuses to push the gears back into position fully.
I believe my next step now is to replace my cable itself
Old Jun 20, 2009 | 12:38 PM
monge's Avatar
my a/c knob has been broken for quite a while i posted a thread in lancer forums and someone directed me here. Im new to all of this so i have no idea how to fix it. i been told to find the part at a junk yard but i cannot install it...
Old Jun 20, 2009 | 01:49 PM
bluebanana23's Avatar
I never knew there was a TSB on this. I just called DOn herring plano mitsubishi and they quoted me 2500 for the job. I was never notified there was a TSB.
Old Sep 21, 2009 | 02:29 PM
GaBe511's Avatar
You have PM
Old Oct 13, 2009 | 09:11 PM
project_skyline's Avatar
How much for these parts along with the cable that goes from the temperature cable to the adjustment on the heater core shipped to 81652? mine has a kink in it.
Old Oct 14, 2009 | 11:03 AM
TheGreek's Avatar
xxxxx
Old Oct 14, 2009 | 11:17 AM
16vTAWD's Avatar
AC temp control cable pn:MR979515 its about $5
Old Oct 5, 2010 | 09:32 AM
Katsidhe's Avatar
Add me to the unhappy list of people who have broke the A/C & heat knob off of their 2003 Lancer.
I did a search on here and saw that I'm basically going to have to replace the entire dash control for one stupid knob, and I also saw a few places recommended to find the part. The question I have is if anyone has a part number or something to that effect so that I know that I'm buying the right part since not all of the sites have pictures. Also, if anyone could recommend which site they bought their parts from, that would be great. It looks like partswebsite.com is the most reasonable at this moment.
Thanks so much for any help.
Old Oct 8, 2010 | 03:58 AM
MikSchultzy's Avatar
That's the issue I am having as well. The cable bends and binds within the HVAC control area - not down under the dash with the gears.
Getting the HVAC unit and disconnecting the cables is a PITA as well. I did this about 2-3 weekends ago when I was working on a few other things (had whole dash out). I tried calling the local Mitsu dealer about the TSB, but they clearly didn't know what I was talking about. I wish I had the actual TSB number then... (I knew of it, didn't know it specifically). I'll have to do this next weekend.
