Preparing car for track -- safety tips please!
Originally Posted by d15b7
besides the motor oil, keep the rest of the drivetrain lubricants fresh (at least follow the 15k mile schedule).
People who have used other brands of lube have reported t-cases failing in just a few hundred miles. Personally, I've had TWO t-cases fail. Both were replaced under warranty because the DEALER used the wrong lube! Now that I'm running the DiaQueen, the problem is solved.
Anyway, considering how much strain the t-case and diffs endure on the track, it's probably a good idea to be **** about your drivetrain fluids. At minimum, you should follow the 15K mile schedule. But, if you have an '03 Evo, I would strongly consider flushing the t-case gear lube with every second oil change (i.e., every 6K miles).
Emre
Originally Posted by nsnguyen
Don't worry too much, you are understandably nervous like everyone else before the first track day
Dave
Originally Posted by Kayaalp
Novice drivers tend to overheat their brakes badly. This is mostly down to poor technique (i.e., dragging the brakes rather than using quick, hard jabs).
Dave
On the topic of drivetrain lubricants, '03 Evos have a notorious problem with their t-cases burning up. The open diff seems to be the culprit, since the '04 RS with the same t-case but an LSD front diff doesn't have the problem. The solution seems to be flushing the gear lube regularly...like with every second oil change. You need to use a GL-5 lube of SAE-90 weight (Mitsu's own "DiaQueen LSD Gear Lube" is what everyone recommends).
Originally Posted by djh
However, having never had a car with brakes like the Evo, my quick, hard jabs were initially way too abrupt! I'm still learning how to roll on and off quickly but smoothly.
The basic idea is to use the brakes for as short a time as possible. You want to generate the maximum possible braking force over the shortest possible distance (obviously, you don't want to just slam on the brakes...you need to apply and release them smoothly). Not only is this MUCH faster than dragging the brakes, like you do on the street, but it puts a lot less heat into the brakes.
The other advantge of this is that you take one variable (braking force) out of the equation. Think about it. When it comes to braking, you have three variables: when to start braking, when to stop braking, and how much force to use. The trick to driving quickly on the track is to be smooth and consistent. It's really hard to be consistent if you're changing too many variables at the same time.
When you brake, you already know where you want to turn-in. So you know that you need to be DONE with your braking at that point. If you take braking force out of the equation, that leaves you with just ONE variable: where to START braking. If you always turn-in at the same place and always use the same brake force (i.e., maximum) you can adjust your entry speed by just moving your braking point closer or further from your turn-in point.
Emre
Dave
djh,
Have you driven at Mid-Ohio? That's an AWESOME track. Maybe not the best for novices but definitely a track for grown ups.
Dave
Yes, love it! I think it's a good thing Mid-Ohio doesn't do open track days like Nelson -- you (by which I mean me) really want an instructor with you. T1 has the biggest pucker factor! I think I'm pretty wimpy but I see a lot of people brake hard for that one. Mid-Ohio is kind of like a good pinball machine, you can have fun just playing it, but it has lots of technical details that can make a big difference.
Dave
Dave
thetinman
17
Sep 6, 2010 08:57 AM
metaphysical
Aug 26, 2004 08:34 AM
