Final consensus on camber plates
Old Aug 8, 2005 | 07:53 AM
russjnco's Avatar
It's tough to describe but it takes bumps differently since the movement is no longer linear. You get a little different contact with the ground when the strut moves with it being able to pivot in any direction.
Originally Posted by EVO8LTW
What do you mean "a little different"? Are you talking about ride quality/noise?
Old Aug 8, 2005 | 08:31 AM
chrisw's Avatar
Originally Posted by DMS_Mark
"The PDE plates for the EVO are sold with DMS. Any DMS vendor should be able to help you get a set.
Caster adjustment on the GC plates is accomplished by a set of slots on the plate itself, it's not like the BMW plates at all. With the EVO application it is possible to set the caster separately from the camber."
Uh, PDE does not make DMS top mounts anymore. These are manufactured IN HOUSE at DMS North America. Also, PDE does not have an EVO top mount or subaru rear or evo rear.
In the next 3 months we will have mazda, honda and GTO applications ready as well.
DMS manufactured mounts are all clear anodized, design has also been upgraded to accomodate strut tower bars as well. Units willl fit on OEM struts, must specify this fitment kit when ordering though.
Regards,
mark
hey Mark!
thanks for the correction. Can we still buy the camber plates separately?
Old Aug 8, 2005 | 12:09 PM
JT-KGY's Avatar
Originally Posted by geminix3
the GC's on my buddy's M3 have caster adjustment, but in the form of a big gaping hole, it's impossible to adjust camber only, or caster only. haven't seen the evo setup to comment, but i didn't like his for that reason.
Like this?? (BMW GC plate)
Old Aug 15, 2005 | 12:15 AM
SS RX7 r2's Avatar
JT,
Have you seen my custom designed caster/camber plates? I had an extra set made to fill the minimum job order that replace JIC's top camber plate as well as other brands.
Old Aug 15, 2005 | 03:21 AM
WarmPepsi's Avatar
Originally Posted by fastevo03
I have Tein TYpe RA that comes with pillow mount. When I set the camber plate on the 0 position, front camber is measuring -1.2left -1.3right. I move almost all the way inboard but it seems like the camber gain is not that much. The other option I can do is to turn the cam bolt that attach the strut to spindle 180 degree to gain more negative camber.
I set the front toe to 0 degree which improve turn in and reduce understeer but sacrefice straight line stability.
not knowing, what kinda toe settings are optimal for track/street. not sure how toe is measured, but obviously, you don't want much of it. a tad in the front, and 0 in the rear?
Old Aug 15, 2005 | 03:31 AM
meanmud's Avatar
I am set up at:
1/8" toe out (f)
0 toe (r)
Old Aug 15, 2005 | 11:52 AM
geminix3's Avatar
hey- just caught back up with this discussion, but i can't see the pic.
i'm guessing it looked kinda like this:
http://www.ground-control-store.com/...2031.75_dp.jpg
... which is pretty much what my friend has. now, we might have been doing it wrong, but the one time i helped him adjust his camber (he had preset marks for street/track settings) it seemed like there was no way to do it while keeping his camber setting intact. loosen up the nuts, and the strut's just kinda swimming around in that big hole in the mount. the website says that camber and caster are separately adjustable so, again, it could have just been ignorance.
i haven't seen the GC evo camber plate, it sounds nice, from what you guys are saying. been waiting to see a coilover from them for a long time, no luck so far...
edit: hey wait, is the GC evo setup just a generic camber plate? i just found that page:
http://www.ground-control-store.com/...egory.php/CA=7
... and i guess the generic 3 bolt plate would work? interesting, for sure. i've been happy with my cuscos, they did what i wanted, but the caster adjustment would be tres cool....
hmm.
Old Aug 15, 2005 | 12:07 PM
geminix3's Avatar
Regards,
mark
that's what i thought- but i clearly saw the PDE plates on an evo at the track. it sounds like you are saying that the PDE mounts came with DMS setups in the past, is that correct? if so, that must be what i saw...
Old Aug 15, 2005 | 12:13 PM
DizzyTT's Avatar
My buddy with an sti just got some zeal v6 (I think they were v6) and they came with camber plates all around, very nice looking and very easily installed.
Old Aug 15, 2005 | 12:22 PM
geminix3's Avatar
Originally Posted by Smogrunner
I have the Ohlin R & T coilovers and Cusco camber plates. I still use my stock rear shock mounts though. I'm looking at these Works rear pillow ball shock mounts:
http://www.worksevo.com/store/produc...roducts_id=157
Should I get them? They are 250 bucks. Should I use another brand. Are the stock ones fine?
smoggy, those are the only ones i've seen for the rear besides HKS, and i like these better. my feeling, though, is that's probably the last thing to replace in the rear- once you've done the rest of the bushings and all the bracing you can, maybe it's worth the tradeoff. just my opinion, of course.
on that note- someone was asking about this or that brand increasing vibration: rest assured, pulling out your nice squishy rubber mounts and replacing them with metal mounts- ANY metal mounts- WILL result in a major increase in NVH. of all my chassis tinkering, this is the one change that was noticed by my wife, who groused about it a bit.
the tradeoff was worth it to me, but the change was indeed drastic. and this was just for the fronts.
Old Aug 15, 2005 | 06:33 PM
tweekscratch's Avatar
I'm getting ready to place an order for a set of springs and camber plates. Based on reading this I'm leaning toward the GC plates and a set of Hotchkis springs.
My only concern is whether or not the plates will break from daily use. Does anybody have any experience with this?
Old Aug 16, 2005 | 01:36 AM
JT-KGY's Avatar
You loosen the 3 bolts outside to adjust camber... but caster hold by those 4
bolts inside shouldn't move... Am I missing something?
Old Aug 16, 2005 | 11:25 AM
geminix3's Avatar
not really- it's more likely that we were the ones missing something. it's been awhile, but i'm pretty sure we only loosened the outside bolts and ended up swinging free in both directions.
made no sense to me at the time, but really- the hardware was different enough from my cusco plates that it was just completely foreign to me.
knowing that the adjustment is definitely separate in our application makes these GC units sound interesting, though. can anyone say for sure if whatever problem they had has been resolved?
Old Aug 16, 2005 | 11:50 AM
geminix3's Avatar
hey! crap! the pic shows up today, i just noticed it! dns problems at my end, i think...
ok, so heres the thing- no, that's not the plate that's on ed's coilovers. see those nice slots that keep the adjustment in a single plane? no such thing on his plates. look at the link i posted, and though the pic is not nearly as clear as yours, you can see the plate has no such slotting.
actually, since i just noticed how to link to an image, i can make it even easier, and maybe find a better shot, too...
here we go:
see the difference? loosen those three bolts, and you're completely on your own....
after a little poking around, this (e46 M3) is the only application i see on their site that is configured this way, so there is presumably a very different method to adjusting it- one that we couldn't figure out in the coliseum parking lot with 15 minutes to spare before his run group.
but i would think that it is actually designed to allow separate adjustment...
Old Sep 5, 2005 | 03:40 PM
DMS_Mark's Avatar
Hey Guys,
PDE originally manufactured our SUBARU FRONT mounts (50 kits total) That was the only production run ever done for DMS.
We have only started shipping DMS TOP MOUNTS with struts included in the price since JULY 1st. Mounts are still available seperatly.
RX-8, SRT-4 and HONDA applications are now available as well.
Mark
