Quote:
this particular set is made of cf weave with the resin applied and then excess removed.
typically wet lay is just cf weave with the resin applied... and left on as dead weight.
the weight difference between frp and wet lay is usually minmal however depending on the "thickness" of the wet lay, it can be heavier than frp that is scantily constructed, however of course scantily constructed wet lay is also more capable of being lighter than frp.
dry lay cf is the lightest and also the strongest.
Full carbon support thats what saves the weight. Carbon cloth is significantly lighter then glass fiber and can be layed thinner for the same/greater strength. But it costs more to build it up using carbon cloth which is why almost EVERY "carbonfiber hood" is heavier than the stock evo hood because they use heavy mat and resin to build-up the panal thicknes to the required strength. That is untill you get to the big buck JDM hoods.Originally Posted by trinydex
frp is fiberglass reinforced plasticthis particular set is made of cf weave with the resin applied and then excess removed.
Thank ya for the info.
Robi are you free to PM about these like middle of this year maybe?
Quote:
you shoudl sell that thing and get a sti
now thats sheddin WEIGHT!
Originally Posted by kingleh@GSC
you wanna shed some weight..you shoudl sell that thing and get a sti
ha ha...
you sti *****....
n
Quote:
Originally Posted by v rod
what's wrong with that?
I am actually very curious on how an STI drives at the track.. I'd love to try one out.
n
I wanna drive one too. haha
And from the looks of things...three of my best friends are gettin STis and i'm getting an Evo. It's a conspiracy. lol
Quote:
I can't wait to drive my car again. Originally Posted by robi
Yes throw me a PM
See you tonight. Give me a price on a trunk installed. How do these cars work below 100 mph without the wing. Would you align it differently?
uh oh....Originally Posted by CRVdrftR05
I wanna drive one too. hahaAnd from the looks of things...three of my best friends are gettin STis and i'm getting an Evo. It's a conspiracy. lol
better be carefull when your around them STY's.. the boxer rumble is known to set off the evos knock sensor....
so when they are passing you... u, just pull over and let them on by... dont wanna get your timing pulled
kingleh
kingleh
Originally Posted by GregGSC
uh oh....better be carefull when your around them STY's.. the boxer rumble is known to set off the evos knock sensor....
kingleh
AW! Are you serious? =_=...so that's how they win....cheating Bas......i mean....those ppl.
BTW. Robi is there a way to install the wing on the trunk? or do I have to drill my own holes?
Annd.....2 more.
Will the hood fit on the IX?
Is the rain-catch transferable?
Thank ya.
whats up with supraforums....
im stuk here in this road race subforum till its back up
wut the hek
Quote:
I noticed that too...Originally Posted by kingleh@GSC
Sorry for the old bump....but I have a question about removing the crash beams.
Did you feel the car get less solid with the front and rear crash beams removed?
Do they offer rigidity or frame stiffening?
