handbrake assisted turns in autox
Originally Posted by conevadr
Anyone with ACD tried using the handbrake on really tight low speed turns? Seems like a little extra rear brake bias while trailbraking could be useful.
evolved04 - When you tried it, did it feel controllable, or just slide inducing?
ratt_finkel - Not allowed?
chrisw - agreed, it would need to be pre-planned, and only for certain types of corners.
daworstplaya - true, but what I was thinking was a little extra oversteer where you need it (entering tight slow 180s), without adding oversteer where you don't (long slaloms)...
thanks for the input
We do motorkhana here is Australia which sounds like much the same thing as your autocross. I believe there are some differences in our cars but regards handbrake I have been told, similar to the old DCCD system in my sti, the ACD opens the centre diff when you hit the handbrake and then allows it to lock oncxe you release it. I have found handbrake turns to be an excellent way to make time on really tight sharp turns but they can be a very risky hero or zero move. The safe way is always to drive it.
Originally Posted by chrisw
YEP.. Usually you end up with the zero move and a whole lotta cones....
Also nothing looks better than all four wheels on fire drifting through a hairpin turn
vizi0n
10
Oct 6, 2017 04:08 PM
ru4real
May 31, 2005 06:47 PM
