Swapping race pads for track days?
Hi Guyz,
I just ordered some Carbotech XP-8's for the front pads and have a few questions about putting them on. Do I need to use those stock metal shims(?) and apply high temperature brake greases when I put the carbotech pads on? I am asking, because the representative at Carbotech said that neither are necessary. Just wanna make sure I do it the right way first time.
Thank you in advance.
smp
smp
Tsurara,
Your help will be much appreciated for the noob.
Check your PM. You posted while I was writing.
Mayhem, Thanks for the advice.
Check your PM. You posted while I was writing.Mayhem, Thanks for the advice.
XP12s, 2-piece rotors, no grease, on the way to a track day. Wife: "what in the heck did you do to the car now?!?" My brakes squeel my clutch rattles and chirps(Tilton)-she thinks the car is always about to break. I can't help it though-I'm addicted to fast
I think shims are a good idea at the track - they reduce the heat transfer from the pad through the pistons and into the fluid.
Originally Posted by ROK EVO
Hi Guyz,
smp
smp
One more question for you guyz. Will I run into problems if I run the carbotechs on the front with stock rear pads? Too much brake bias???
