GSC center diff - TESTED w/ VIDEO
Is this enough of a change to generate snap on-throttle oversteer at lower speeds? In a naturally aspirated rwd car, tail out attitude is very easy to modulate since power is directly related to right foot movement. Since the Evo deals with boost response, does that create a more difficult car to drive under certain conditions?
If the speeds are low enough, the Evo is happy to go tail out. Increase the speeds and the problem goes the other direction where it just grips. Does this exacerbate the problem?
-Jon
-Jon
The diffs are good though... I did end up blowing my rear diff, but that happened before I installed this center diff
n
-Jon
-Jon
I havent done donuts in the car yet after center diff install.. as soon as my tires are worn down & useless I will though & report back to you
But yes, this makes the rearend looser, at low & high speeds... no more corner exit push.
n
I know evom user 'thechoc' has it in his acd equipped car but I think he works overseas & does not have time to test his car out.
somebody with and ACD car buy this thing already & let us know!!
n
Dave
My car will be available for testing, but it may be a couple of months till it goes back together. Car will be an 05 with an 06 drivetrain, and is being built for PPIHC. It will see plenty of track time while we're trying to dial it in, and an aftermarket ACD controller is on my list of 'must haves.'
One unit to check out is the combined Pectel ECU and diff controller. Both are plug and play and can interact with each other. Very trick stuff.
