Setup advise needed
Old Jun 7, 2007 | 09:08 AM
KZEVO's Avatar
Setup advise needed
I have a track day tomorrow and forecast is for thunderstorms all day. Wondering what will be the optimal set up for tomorrow.
I have new Nitto NT1s and PF01 (front) and PF 97 (rear) that i was planning on running initially. Should I go with this set up in the rain or will high friction pads\aggressive pads not be optimal for a wet track? Also will the Nittos be ok for the rain (given they are new so they have full thread).
OR should i stick with my street set up which is OEM tires and Ferrodo DS2500 pads? The track is very brake heavy (not really a fast track) so in the dry 2500s fade.
also what's the optimal cold tire pressure to run with the Nittos?
thanks
Old Jun 7, 2007 | 09:24 AM
swordfish's Avatar
As long as there is not deep standing water the Nittos will be fine. I've even driven them in standing water and they were still good. AWD helps a lot in the wet. Also, last time I ran in the rain I just kept my 01's on the car.
jeff
Old Jun 7, 2007 | 09:39 AM
KZEVO's Avatar
thanks Jeff that's very helpful. how much air were u running in the tires?
jeff
Old Jun 7, 2007 | 02:57 PM
Richard EVO's Avatar
Full tread Toyo RA-1s are often used as rain tires. I think you should be fine on the NT-01 as long as they are new and have plenty of tread block. Remember to do all the same things you do in the dry, only SLOWER.
Old Jun 7, 2007 | 04:08 PM
marksae's Avatar
Get ready for the PF brake dust to cement to your wheels after one session in the wet. :X
Old Jun 9, 2007 | 08:09 AM
KZEVO's Avatar
it didn't end up raining and it was a blast. have some other questions and will post in another thread
