Ralliart Active Center Differential Controller
If you're after a MoTeC unit, check with some of the rally shops, as they'll be more able to help you with tuning. They may or may not have auto-x experience, but I'm sure they'll have plenty of thoughts to help you on your way.
Keep in mind that a top level rally car typically uses 1.5 way front diffs and 2 way rear diffs, so unless you're running those, the Ralliart pre-programmed diff programs typically aren't "built around your setup."
Dave
Dave
Though, looking at peter*g's link there seems to be an option for both rally spec and asphalt spec
I chose the MoTeC b/c my big event is Pikes Peak which has both tarmac and gravel on the same course, so swapping between Ralliart boxes mid run isn't an option. I just wish I had more time to go out and get some testing done.
Dave
I don't think that's accurate. My understanding from everything I have seen is that it's designed to work with the Ralliart diffs, and they leave the rear diff alone. Being that the Ralliart controller only affects the rear diff, this set up should be designed for a stock Evo IX.
I do wish I had looked more into this before I purchased the Gruppe-S reflash - http://www.rhdjapan.com/ralliart-act...ion-viii-54389 so this is a definite direct swap for the USDM IX then? It does support cars without AYC, but just checking if there are any other compatibility concerns. Asphalt road spec certainly seems the way to go: I found this old old thread about it that has a little bit of detail about it: https://www.evolutionm.net/forums/3754948-post7.html
Dave --
I've been talking with Shep about drivetrain options for my car for 2010, and he does offer an upgraded rear diff with extra friction discs and you've got the option to set it up in different locking configurations.
Dave
Agreed that many do use the "stock" rear diff, but I'd be curious if anyone still has them in a stock configuration.
Dave
Dave
One more thought...and I'll defer to Peter on this one if I'm off the mark:
If you've ever watched a tarmac rally, you'll notice the guys are driving a car very differently from someone driving at a race track.
Dave
Dave
Dave - what are you running in the rear diff right now, if you don't mind me asking? Along with shep, there are a lot of diff options so I was just curious. After doing a fair amount of research i decided to go with the Cusco type RS. It was between this one and the carbonetics - I believe both Tre and Shep's options, being modifications of the stock rear, don't provide as much lock up as these aftermarket units. Just stating, not meaning to offend anyone etc.
I have run Cusco's in the past (1.5way front, 2 way rear), but I suffered failures on both of them. I'm not sure I can point at the diffs as what failed. I had a buddy's shop do the installs, and I'm not sure they got everything setup properly.
I'm sticking with the "known" Evo shops now, as one of those failures cost me a win last season when I had to retire with a lead of over a minute.
Dave
I'm running a Carbonetics setup for 1.5-way currently. I'm most likely going to have Shep put together a modified stock one and if I like that, I may just stick with those from here on out. No complaints at all on the Carbonetics unit so far.
Dave
Dave
Same here about the "known" Evo shops. I spoke to AMS about installing the Cusco, and what they actually do is send it to a specialty shop to shim the diff properly - I heard that is a necessity for the Cusco in order to function properly and reliably.
Dave
Dave
Dave
Not that different, actually. I ran softer at Targa than I would on the race track, but not by much (1-2kg difference), and I ran taller for better clearance and shock travel. The tarmac rally set ups on the really fast cars look a lot like road race set-ups, just with spring rates to match the condition of the surface.
FWIW, I was just basing my comment on watching rally cars at a tarmac rally vs. watching a road race. Completely different types of lines, with rally guys often throwing the car around, whereas at a road course, everything is about smooth smooth smooth.
Dave
The other thing you need to remember is that Helical-type diffs stop working when one wheel gets in the air (basically sends all power to the wheel in the air). So, if you're running a set up that lets you lift a rear wheel (which many auto-x guys do), then a standard LSD is going to work best.
