RA-1 Tire Pressure
Old Jun 22, 2008 | 12:48 PM
jid2's Avatar
RA-1 Tire Pressure
So it had been a year since I had been to the track and I couldn't remember my tire pressures I usually run. Tires are 255 RA-1's. Alignment is -3.7 degrees of camber up front and a touch of toe out. -2.0 degrees camber rear, zero toe.
I started around 42psi. The car seemed kinda loose so I lowered to 38 psi, it felt better. Then I dropped it to around 36 psi, again it felt a little more planted.
What pressures are you boys running?
Old Jun 22, 2008 | 01:20 PM
cfdfireman1's Avatar
hot 42 front 44 rear
Old Jun 24, 2008 | 10:09 AM
boomn29's Avatar
40psi hot. But I'm not running -3.7 up front; whew!
Old Jun 24, 2008 | 11:52 AM
jid2's Avatar
-3.7 FTW! I have my bolts on the KW's maxed out and the camber plates maxed out.
Turns out the front end was too low as I didn't raise it after I slammed the camber. I'll get that fixed. It looks cool with the tires tucked but not great for front traction.
