Evo VIII Aero
DHP Composites contact is DHPComp@gmail.com (no website)
I'll let you read up on undertrays and aero on your own. It's just physics. Works the same way as a diffuser or wing on the rear of the car, creating an area of high speed/low pressure air and using flow turning to apply a force on the car. . .
Depending on the shape of the underside of the splitter/undertray, it also helps direct air out the front wheelwells, keeping that air out from under the center of the car. This has benefits also. . .
Saying you're having a hard time being convinced that flat is not best, well . . . that's like saying you're having a hard time being convinced that the stove burner is hot when it's red. I can tell you all I want to, but you either have to experience it first hand (burn yourself), or read up on it and understand WHY the red stove burner is hot and believe it.
http://www.mulsannescorner.com/
http://www.grc.nasa.gov/WWW/K-12/airplane/bga.html
http://www.grc.nasa.gov/WWW/K-12/airplane/presar.html
As for the "standing" on the splitter, its a saying, its not a do-or-die rule. if you have a honecomb core carbon splitter like race cars, you would break it by standing on it, but it could hold 5-10 times your weight sprea out over the front. All its saying is, a properly designed splitter/tray can generate more downforce than you weigh, and should be able to hold that "weight".
No official website yet, but you can check out some additional pictures on the photo page below:
http://www.flickr.com/photos/dhp_composites/
If you have any questions please let us know.
Thanks!
Thanks!
I give it full credit for sticking out farther then any other splitter i've seen on an evo though.
Rain doesn't bother me. That's what I have a set of Hoosier Radial Rains mounted on the stock wheels for!
Please feel free to comment further on what does or does not work after you've spent hours testing aero parts in a wind tunnel. Or burned up many tanks of gas testing different bumpers and splitters and undertrays. David at DHP has been there, done that. I've been there, done that. Voltex has been there, done that. (granted, they're in a whole other league)
As for my "ride hight" - the front splitter barely scrapes the ground (on the front outside edge) when trail braking into a hard corner. The side skirts barely scrape the ground when the car sees nearly 100% weight transfer to that side. How much lower do you want me to go??
or like this?
Wind Tunnel testing?
1. This site is the awesome. http://www.mulsannescorner.com/ Thanks for sharing!
2. Lets not confuse similar shape and design with actual knowledge.
Sure, there is precedent for using shaped underbellys and underbody vanes to direct air from underneath the car into the wheel wells (actually more likely the shaped areas behind the wheel wells).
e.g. http://www.mulsannescorner.com/audir8-01-3.html
Show us a windtunnel video or a CFD study on an EVO and everyone will be the wiser.
3. With that said, a shaped splitter will be something I'll be looking to test for next season.
-yang
Team Lee Myles Transmission
P.S. Usually someone with superior knowledge does not resort to overtly ambiguous analogies. By the reasoning presented, I should just as readily believe the stove top is hot when green.
-yang
Here is a pretty good read on the basics and some graphs thrown in with it:
http://engineering.union.edu/~brunob...rodynamics.ppt
http://www.slideshare.net/heeltoer/m...-presentation/
Here is another pretty detailed doc about the Evo vortex generator.
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
Interestingly the optimum combined drag and lift reduction was achieved and tested at 50 m/s or 112 mph!
Nice video Marshall! I didn't know you were on your school's FSAE team. So what did you guys learn from testing the aero package on that car. How does it compare with what UTA has been running the past couple years?
I know a couple years ago they ran something much smaller and compact than what you have on the car above, but they said that idea didn't really pan out. That rear wing element is pretty huge. Did the front end make that much grip that you needed that much downforce in the rear to balance it out?
How does what you learned in FSAE transfer over to the EVO?
UTA's aero package had a far superior build quality and weighed a lot less. We were probably fairly close downforce wise though.Honestly? I learned that there isn't much to be gained performance wise (at normal autox speeds) for the amount of weight you can add in aero devices, but that speed dependent stability augmentation is a good thing.
Oh and you can spend a lot of money fixing broken carbon parts when you hit cones.
Speed dependent stability augmentation? What do you mean by this?
I know for my car we set it up with no aero to rotate pretty well and be a little loose in the rear end. I added the splitter and the thing turned into a snap-oversteering b!tch. About the 3rd cone into a slalom, if you were pushing it, it would just come around on you. We had to slow down to not spin out. Then I added the wing and now you can take a slalom as fast as your hands can move the steering wheel . . .
