Building a GT Wing
Old Dec 9, 2009 | 01:34 PM
  #136
jid2's Avatar
Originally Posted by aeroweenie
Looks good jid2. What is the approximate thickness of the graphite skins?
It's 2 layers of 5.9oz cloth, so around .025" thick.
Old Dec 10, 2009 | 04:06 PM
  #137
talentsearch301's Avatar
Next time use "Max Clr" resin... it will take give it that shiny finish look without havin to spray clear...
Old Jan 4, 2010 | 10:25 AM
  #138
jid2's Avatar
Did a quick static load test. Put what I had laying around on it. Heavy jack stands, flywheel and clutch, and a chop saw!
Then added some tufting to go look for the angle of attack where the wing stalls. So far so good, I didn't have enough time to do anything past the level to ground test for now.
Old Jan 4, 2010 | 03:06 PM
  #139
cmj's Avatar
cmj
Can you post the video?
Old Jan 4, 2010 | 03:35 PM
  #140
nothere's Avatar
a wsp was pretty quick to pull me over Saturday, were you out earlier in the day?
is a ground test a still shot or were you out on the road?
Old Jan 4, 2010 | 03:50 PM
  #141
jid2's Avatar
Yeah, it's boring now, I need to increase the angle of attack and get it stalling.
Bruce - I was out for about 5 mins on Sunday, that's it. WSP must of had other reasons. For whatever reason I never get pulled over in the EVO. I've been out tuning the car and will be sitting on the side of the road making adjustment on the laptop, with the numbers on the side of the car - and cops drive past me all the time without even a word. Now I'll probably jinx myself.
Old Jan 4, 2010 | 03:57 PM
  #142
Hiboost's Avatar
Nice downforce thread going on here!
Since changing the angle of the wing by only a few degrees can alter the downforce, would it make sense to somehow make the base of the wing adjustable by increasing the forward angle as much as 5* at the rear of the base where it attaches to the trunk?
I have the SSS Evo X wing and for larger tracks where high speed stability and extra downforce might be beneficial. I was thinking that creating an angled spacer to raise the rear mounts about 1" would net the ~ 5* that seems to be a reasonable goal. I would of course zero in on the exact measurements before attempting this type of mod but it seems straight forward enough and should work fine assuming the mounts are made strong enough. The wing itself could also be raised closer to the roof line if that also makes sense when desiging the spacer.
Has anyone attempted this or tested the wing before and after such a change?
Old Jan 5, 2010 | 09:09 AM
  #143
jid2's Avatar
Video of the first test on the lower surface.
http://www.vimeo.com/8547243
Old Jan 5, 2010 | 09:47 AM
  #144
cmj's Avatar
cmj
Thanks for posting, looks good. Maybe you can construct a cowling for the mount, to cut down on the turbulance in that area.
Old Jan 5, 2010 | 11:24 AM
  #145
honki24's Avatar
Does it block your rear view? I hated that about my stock GTC wing. That's why I had some custom risers made so that it is at the roofline. Really hard to manage any GT3s in the rear if you can't see 'em. I even have a broadway convex rear view and it really sucked to have that wing in my rear.
Old Jan 5, 2010 | 11:52 AM
  #146
aeroweenie's Avatar
Cool, looks good! I think you could shorten the tufts and perhaps use thinner yarn (if you can still see it). The aft-most should not extend behind the trailing edge of the wing. Looks like you've got some sort of disturbance going on about 2/3 of the way to the tip, perhaps a vortex/separated flow from the shoulder of the roof. Not much you can do about that.
Old Jan 13, 2010 | 09:21 PM
  #147
jid2's Avatar
I picked up a vinyl plotter so I can create graphics for my car. It's a tool I've almost bought a handful of times over the last few years - and I finally pulled the trigger. It's pretty cool, and I've already made lots of stickers - like prank stuff for guys at work.
First project was the wing...
The wing with treatment.
The concept for the car.
Old Jan 14, 2010 | 06:46 AM
  #148
Lazyfong's Avatar
What vinyl plotter did you get?
Old Jan 14, 2010 | 08:40 AM
  #149
jid2's Avatar
it's a creation pcut 24".
Old Jan 14, 2010 | 01:38 PM
  #150
bpi's Avatar
bpi
The wing looks awesome mate!
Not too sure about the camo green on the outside of the car. Definitely go the camo look in the engine bay as you've done though. Of course, personal preference, and I'm sure many people will say they won't like the new look of my car, but only you have to be happy
So what's next on your never ending list of fantastic DIY jobs?
