Super Taikyu Endurance - engine regs?
Hi guys, I'm in the uk and am looking at buying a evo 8mr engine out of a class 2 super taikyu race car that was imported to the uk last year.
the seller has listed the spec but does not know what the pistons, rods and crank are? (he says engine is good for 600hp
what are the rules/regs with regard to tuning the engines in this race series? - I've tried searching around the net to no avail.
here is the spec for the engine for sale (its all he knows as all receipts are in japanese and he had them translated)
he we have an evo 8 mr engine. this was running in my evo 4 that i broke for parts.
Car has covered 63,000 miles the engine has covered a lot less as it was rebuilt just over a year ago.
Engine EVO 8 MR4G6
Proffessionally built by Koyama Garage Japan)
Built for the Super Taikyu Endurance Series
Built to Super Taikyu regulation spec.
Engine EVO 8 MR4G6
Engined bored 0.25 Over Sized
Uprated pistons, with short skirts and Floating pins
Competition bearings
Crank lightened, worked and balanced
Rods lightened and balanced
Modified sump
Cylinder head ported
Light weight high rev capability rocker arms fitted
Titanium valve retainers
TOMEI uprated Valve Springs
Engine designed to rev to 8,000 RPM
Large volume lash adjuster
Magnesium Works head cover
TOMEI Cams IN 260 10.7 , EX 260 10.2
HKS Aluminium cam pulley
EVO 8 Ribbed cam cover
EVO 6 Throttle body
Low temperature thermostat 74 degrees
Oil thermostat 80 degrees
as u can see this is a top spec engine. im afraid the pistons are of unknown make, as i dont have receipts for the build as the car was imported from japan. the car was built to a huge spec and the engine is no different. the engine was running around 380bhp when in the car as was only running a modded evo 6 td05 16g turbo with 10.5 hot side. with a bigger turbo this engine would run 600hp no probs.
if I buy the engine then I will be running it at approx 500hp but without knowing what the rods, pistons and crank are then I dont know if I should risk it???
thanks fo your help
Mark.
)what are the rules/regs with regard to tuning the engines in this race series? - I've tried searching around the net to no avail.
Engine EVO 8 MR4G6
Engine EVO 8 MR4G6
Modified sump
EVO 6 Throttle body
thanks fo your help
Mark.
georg1970
50
Dec 20, 2021 03:19 AM
DrivelineSales
Jan 13, 2010 10:59 AM
RALLIART/LANCER
61
Sep 27, 2006 12:45 PM
