Hot Brakes - Undertray the cause?
Old Dec 10, 2009 | 10:00 AM
tyre11c0rp's Avatar
bump in case there's an update to this thread.
I have the exact same setup (DTC60, motul, Forged ducting kit, ss lines) minus the beatrush tray, and am considering getting the tray ... unless it's introducing more issues that weren't solved.
any updates from later in the season?
Old Dec 10, 2009 | 10:24 AM
boomn29's Avatar
Sure. I ran the rest of the season without the Beatrush undertray - with zero issues.
I do want to use the tray though. I definitely think it'll reduce overall wind resistance and protect the underneath from debris that might get kicked up.
My winter plans include a complete rerouting of the brake ducting. That's really the only logical explanation, in that the brake ducting just wasn't allowing enough air flow through.
Old Dec 10, 2009 | 10:35 AM
kyoo's Avatar
That's really weird! I was planning on gettin gthis undertray, I never heard anything about this before.
I wonder if I'll have the same effect.
Keep us posted!
I wonder if this will change with stock brake set ups
Old Dec 10, 2009 | 01:16 PM
Balrok's Avatar
I put on the APR undertray/diff last month and attached "sacrafical" home depot ducts with the same size output as the AMS plumbing and riveted them to the back BOTTOM of the tray. Since it's a race car the only issues I have are when i'm loading/unloading it on the trailer, I have to take it slow as it clears by a few centimeters. If I catch debris on-track it's an easy and cheap fix. Also, I get a metric ton of air from that low pressure area because it took almost 3 laps to get my brakes up to temp rather then the 1.
Old Dec 11, 2009 | 12:10 AM
kkrproducts's Avatar
If I were you, i'd move to the 3" tubing. I havent ever heard of teams using any size less for braking.
Try to stay away from using ducts mounted under the car. We tried a similar set-up on a GT3 car and with the help of temp probes found that it was actually heating the brakes because they were just above the asphalt and sucking the "heat" put off by the surface.
Also, have you looked into using in-line fans? They are pretty cheap and incredibly effective.
http://www.hrpworld.com/index.cfm?tp...action=product They can be found cheaper then this, I just grabbed this link quickly. Just wire it to a positive source, mount a switch in the car, and you're good to go.
Old Dec 11, 2009 | 06:44 AM
boomn29's Avatar
Throw up some pics when ya can.
Old Dec 13, 2009 | 06:16 PM
kyoo's Avatar
has anyone else experienced any issue like this?
Old Dec 13, 2009 | 06:22 PM
Sharkbite2000's Avatar
Dam that weird, I have the undertray and I have not experiance any of those problem's, but then again I really don't use brake's that much. I did the Redline time attack in NJ and didn't have any issues.
Old Dec 13, 2009 | 07:08 PM
kyoo's Avatar
is your brake set up stock?
Old Dec 13, 2009 | 08:02 PM
boomn29's Avatar
I ran the undertray at a RTA event myself too. Running just 3 laps on Sunday in the actual TA sessions even in 90+ degree heat and tons of humidity wasn't a problem. However, I did boil the fluid on Saturday in the practice sessions. I could feel the pedal getting soft so I took a cool down lap and like 4 turns later I had nothing. Fortunately I was cruising at like 70mph so I barely went off.
Here's the crazy part - it's the same exact track and same extra straight-away I had the big issue a few weeks later!
Like I said though, I ripped off the undertray and everything was great the rest of the year. I also switched to AMSoil DOT4 brake fluid and I like it better as well.
Old Dec 13, 2009 | 09:18 PM
I'm stock , I dont even have the duct kit on it hawk pads and motul brake fluid.
Old Dec 15, 2009 | 12:23 PM
rawkus's Avatar
Sharkbite, no offense, but you weren't pushing hard enough at that event to overheat the brakes.
I have had brake overheating issues WITHOUT an undertray... go figure
I do not currently run ducting and have not had any issues since going with the undertray, running Racing Brake ET800s and ATE Superblue. I have since upgraded to stainless steel brake lines, but have not been to the track since these upgrades. My calipers front and rear are untouched too, no new seals or any changes besides fresh fluid ALL the time.
Dan
Old Dec 15, 2009 | 04:30 PM
Dan
I know, I know, I didn't want to get my pretty red Brembo's ugly brown
But I did use them, I needed new brake pad's and new fluid the very next day I didn't even want to use them on the NJ pike because they was squeaking like crazy!!!
Old Feb 2, 2010 | 08:17 AM
boomn29's Avatar
Going to give this thread a bump.
Talked to a few people about the braking issues I experienced last year after installing the Beatrush undertray. I seem to be in the severe minority and I'm not exactly sure why.
I would like to re-install the tray for this season but I'm obviously hesitant of encouraging over-heating issues again. Open to more ideas!
Old Apr 7, 2010 | 01:48 PM
kyoo's Avatar
bump - any resolutions? I decided to go with the stock undertray once again instead..
