lots of Caster desired for autocross?
Old Feb 8, 2013 | 03:37 PM
  #31
03whitegsr's Avatar
You can start to reach the 7-8* caster range when you start getting really low on ride height. More normal ride heights, you'll probably cap out around 6*.
Yes, caster changes will change steering characteristics including bumpsteer and ackerman angle. Not significantly, but it is there. It wouldn't be too difficult to add adjustable bumpsteer to these cars...
Old Feb 13, 2013 | 02:43 PM
  #32
nollij's Avatar
Originally Posted by JDavenport
Actually, If you are trying to stuff wide tires under your Evo, the PSRS moves the tire forward in the wheel well. Then you can use a plate (like the Cirodesign) to move the wheel back towards the center of the wheelwell and minimize clearence issues. All while adding even more camber.
I don't take credit for this, RTErnie clued me in.
Yea. This is pretty much what I did. I maxed out Caster with the Ciro plates until I had an acceptable amount of rub on the rear fender well with 285/30/18. On full lock it will rub slightly with full tread tires. Currently running 5.4 degrees I believe at a 1.25" front drop.
Dallas J
Nov 30, 2017 11:41 AM
Dallas J
Jan 15, 2017 03:52 PM
domyz
21
Oct 23, 2016 10:31 PM
Cudi
14
Apr 24, 2013 08:16 PM
Fair
Sep 24, 2009 09:09 AM
