What gauges for a track car?
Old Oct 4, 2009 | 02:26 AM
Evo_Jay's Avatar
I have searched a lot, but couldnt find recommendation for the best 4 gauges to have for road racing.
So whats the best 4 gauges for a track car? So far im thinking
Boost
AFR
Oil pressure
EGT
Old Oct 4, 2009 | 03:21 AM
BoostJunky78's Avatar
I would recommend Boost,Afr, and Oil temp.
Old Oct 4, 2009 | 06:18 AM
EvolvedMR's Avatar
if you have afr, egt not neccessary. I had egt but by the time you notice its high its probably too late.
I would say oil pressure, oil temp, water temp, boost, afr. make sure the warning buzzer is clearly audible and any lights are front and center.
Old Oct 4, 2009 | 06:35 AM
skyblas's Avatar
boost, afr, oil pressure and water temp
Old Oct 4, 2009 | 07:46 AM
o-townFLA's Avatar
Water temp, Oil temp, Oil Pressure, Boost, and a good AFR/EGT gauge
The true ones should be Oil Temp and Water Temp, as those are the ones that'll take you out...
Old Oct 5, 2009 | 12:44 AM
Pure EvoIX's Avatar
so is 280F oil temp and 1600F EGT bad. Cuz thats what im getting at Buttonwillow and Thunderhill in California. Sorry if it was off topic a little.
Old Oct 5, 2009 | 11:56 AM
o-townFLA's Avatar
280 is quite high as a normal temp is about 212 and 300+ is dangerous;y high. What viscosity oil are you using? Maybe you should change from either a higher or lower weight oil, depending on what your using now...
Old Oct 5, 2009 | 12:08 PM
boomn29's Avatar
As stated, it really depends on what oil you are using and how often you are changing it. If you're using Mobil 1 and/or changing every 3k miles with that - then you've got a problem awaiting you. If you've stepped up to much more frequent change intervals and to a better quaility track-worthy oil like AMSOIL then you should be ok. It goes without saying you better have a safe tune too!
fwiw; I see 255-270 degrees in my car. I run AMSOIL 10w30 'dominator'. I've done a few oil analysis reports and the engine is really immaculate.
Old Oct 5, 2009 | 12:44 PM
newevil's Avatar
Boost,afr,oil temp,oil press,voltage ,water temp
