**Touge Factory / STANCE Time attack Evo 8**
Thanks guys...
The hub that split is being taken care of by the manufacturer. It was supposed to be "unbreakable"....
Due to the hub issue, our rear diff suffered some damage as well. That is being taken care of as we speak...
Thank you guys for the support!
are these the driveshaft shop rear hubs you guys broke?
Is that active aero on the rear wing? Looks like different AOA's in the pics from static to racing. Or were you testing different settings.
If so what are your impressions?
badass!
badass!
Sorry for the late response.
I am using the AIM dash with all engine parameter sensors and shock sensors
The turbo currently used is a hta3582. most of the dyno sheets have been posted in the dyno section, except the last tune i had in Las Vegas by FXMD. It may seem weird, but this car has been "weird" since i got it. It makes as much power as people running hta3586 turbos, at less boost.
Yes, that is an active wing currently on the car. We are still testing the wing and changes have been made since the last event.
