929 Evo - Gingerman - 1st in TTA and track record!
On a serious note, congrats yet again Nate. Btw, maybe i missed it, and i cant tell by your pics, but did you remove the splitter also? Im no aero expert, but wont a wing like that be counterproductive without a splitter, or something to balance out your front end? I imagine that Kognition wing creates more downforce compared to the OEM wing.
On a serious note, congrats yet again Nate. Btw, maybe i missed it, and i cant tell by your pics, but did you remove the splitter also? Im no aero expert, but wont a wing like that be counterproductive without a splitter, or something to balance out your front end? I imagine that Kognition wing creates more downforce compared to the OEM wing.Front splitter is gone. I ran w/o it last event using the APR wing; and ran w/o it this event using the Kognition wing too. I just don't have all the pts needed to run that flimsy APR splitter in TTA; let alone a proper one.
There's plenty of examples of other cars out there with a big rear wing and no additional front downforce. So I'm giving this a shot and we're planning on re-aligning the car to take advantage of this setup. Will it work; we'll see!
Since I had the APR adjuster break at my first event; I've actually carried the stock wing to my last 3 events! Just in case! I'd like to put it back on and see how much the rear loosens back up. I think that'll be a test for the next time out!
I'm sure this Kognition wing, or any rear wing for that matter, is limiting my topend. I know they ALL contribute significantly under braking... you can feel that for sure!
I use econolite composite panels for splitter material. Cost is inexpensive $90 for 4x8 sheet. Holds up well using (4) APR splitter hardware sets. The splitter depth will make substantial front downforce changes.
Im going to use alumalite. How do you mount it so it doesn't angle up without adding front facia.
And if you have a IX; our bumper isn't level... So it ends up looking like mine does; which probably isn't ideal. So I decided to try another route for pts. I might come back to this though...
Thx Ed.
That's good to know. Im not looking for anything that provide more down force than th APR at this point but I might have to when I get the front splitter and need to change the balance of the car. Looking forward to more reviews about the rear wing.
Well done! Gingerman is an hour from where I used to live but never got out there. That will change when I move back.
How do you like the AST's? Our shop sells a lot of them and does our own in-house valving. Ive been debating throwing a set on my evo but Im saving my pennies first. We'll be at a few events along the eastcoast this summer. Ill come check out the car if you happen to be there too.
Anyways; yeah I really like the AST's. I have the singles and honestly I have not even touched them! No ride height or rebound changes since they've been installed. I just haven't needed to. That tells you something about their off-the-shelf valving right there.
They definitely offer more droop travel; which is something our cars need when running sticky tires. If the tread isn't on the ground; you aren't putting the power down!
