Harnesses for AutoX
Harnesses for AutoX
Evo X owners,
What kind of harnesses are you guys running for autocross and HPDEs? I used to run a Schroth Harness Quick Fit on my STi but they don't make that for the Evo. Will the Schroth Rallye 4 fit? Or what other brands are good that can be taken on and off for daily driven/autox vehicles?
I know a couple guys including myself that use the Schroth Rallye 4 ASM. I don't recommend it for street use, just autox and HPDE.
Edit: Just noticed you drive a X, I don't know if the Rallye4 will fir that or not?
There is a plug in the drivers side buckle. Unplug it and you will see it's a button that is pressed down when the seat belt is fastened. Just depress the button and wrap it up with electrical tape. Then zip tie the plug and wire under the seat.
Yeah. Many DE groups (like NASA) wont allow any 4pt harnesses anymore. Even if they are like the Schroth with ASM. AX -- not an issue. But for DE events, they want 6 (which needs a cage to do right) or OEM DOT belt.
Rob
ps : do not get a CG lock it is useless. Get a schroth if the club let you run it or you stay with a OEM set up, as Smike said it.
Excuse the thread jack...
What's the min. requirements for the harnesses in something like NASA? Do they need to be FIA approved or can you run something like crow harnesses that are SFI 16.1 approved? Been awhile since I read the handbook.
SO you will not get something "out dated "
LV///R
Apr 13, 2017 10:06 AM
itzcharlez
Aug 17, 2008 09:39 PM
