Good overall clutch for Time Attack/Time Trail. Help!
Old Aug 8, 2011 | 11:19 AM
boomn29's Avatar
No. I think this is what I have. I could check with AMS if you want; they recommended and installed it.
Exedy Mitsubishi Lancer Evolution VII/VIII/IX Twin Metallic Clutch Kit
http://www.amsperformance.com/cart/E...lutch-Kit.html
Old Aug 8, 2011 | 11:33 AM
Ev0_J0e's Avatar
Still doesn't seem to bad compared to a Quartermaster, If you could verify that this is what you have i would greatly appreciate it. I need a new clutch also and you seem to be very successful in the sport and this clutch is obviously proven to work.
-Thanks alot, Joe
Old Aug 8, 2011 | 12:59 PM
boomn29's Avatar
This should be it. I checked my old work order and it states:
Exedy MM022HD
I also did the AMS Clutch line, Lower Clutch lines and AMS Front Motor Mount which were < $150 total.
Old Aug 8, 2011 | 01:14 PM
Ev0_J0e's Avatar
Well i really appreciate it, thanks alot.
sorry to hijack the thread a bit
Old Aug 8, 2011 | 01:20 PM
L888Apex's Avatar
I use a ACT XTSD and I get lock out occasionally when I shift higher than I normally do ~7,500rpms or so. I'm sure you can adjust the pedal so that it doesn't do that, but i'm too lazy and it hasn't become a major problem with me. I have about 12 track days and 60k miles on this clutch so far
Old Aug 8, 2011 | 02:06 PM
Kidloco51's Avatar
Well I am between a quatermaster or a Exedy Twin.... Time to save my pennies.
Old Aug 8, 2011 | 05:58 PM
JDavenport's Avatar
Carbonetic Twin. I tried the cheaper route and went through 2 clutches in 12 months. The cabonetic has about the lowest rotating mass on the tranny input shaft of any clutch (easier on synchros) and for a twin it drives like the OEM clutch. It's also a push conversion and I think has a much better and more consistent fell than the pull setup.
Just got back from giving it another workout at Road Atlanta.
Old Aug 8, 2011 | 10:15 PM
EVOlutionary's Avatar
Exedy Twin is absolutely the way to go if you driver your car on the street at all. They have an ultralite version that they sell in the USA now that is about 7# lighter than the normal Exedy Twin or HD Twin.
Normal Exedy Twin - MM022SD
Exedy HD Twin - MM022HD
Exedy Compe-R Twin - MM022SBL
BTW - I have both a new or a used Compe-R for sale. Have 3 of them and need to get rid of one. . .
EVOlutionary
Old Aug 9, 2011 | 07:20 AM
Balrok's Avatar
Push or Pull?
Old Aug 9, 2011 | 09:51 AM
L888Apex's Avatar
Is it true that the twin plates don't last long if you daily drive your car? I have a friend that DD his car for about 10-15k miles and the clutch needed a re-build after just being street driven for that mileage?
Spazm
May 24, 2016 09:15 PM
AutoMotoSports
Feb 25, 2014 12:15 AM
housedj
Mar 27, 2009 05:45 PM
bbbwrx
For Sale - Cars For Sale
Aug 18, 2008 07:19 PM
