ExtremeDSM "Takin it to the EXTREME!!!"
Old Feb 29, 2012 | 08:50 PM
  #46
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Originally Posted by ExtremeDSM
The rear sway bar is in the car already and have not really looked into that yet. I also read that the clutches in the rear diff were put in wrong from the factory. Have not really looked too much into that either.
https://www.evolutionm.net/forums/ev...y-factory.html
My car has this done and it made a huge difference. Since you won't be limited by rules, you can go with one of the more aggressive kits...
Old Mar 1, 2012 | 05:54 AM
  #47
getsideways's Avatar
Off topic but arent the properly packed rear diffs more prone to breaking on a moderately powered car, whereas with the factory setup they were rarely heard of breaking?
I only ask because at GTA in Joliet Tony from UMS said they had been through 3 repacked Diffs already on their car.
Old Mar 1, 2012 | 06:38 AM
  #48
ExtremeDSM's Avatar
Yeah, I don't want something that is going to break. Getsideways should get a TRE one and let me know how it is.
I want to work on my car!!!
Old Mar 1, 2012 | 06:41 AM
  #49
I Would but with the way things are going lately it wont be back until this NEXT winter...
FIXED
Old Mar 1, 2012 | 06:44 AM
  #50
ExtremeDSM's Avatar
Perfect, it still is winter.
Old Mar 1, 2012 | 07:55 AM
  #51
R/TErnie's Avatar
I have TRE MAX lock rear diff... It's AMAZING.
Old Mar 1, 2012 | 08:11 AM
  #52
ExtremeDSM's Avatar
^Did you get any of the options with it or just the basic one? I am not one of the greatest drivers on the track so I am a little scaird to change anything like that on my car.
Old Mar 1, 2012 | 08:26 AM
  #53
mullen's Avatar
just reassemble yours...I'm sure the TRE one is amazing but you can do yours for free and then when you're comfortable, step up to the TRE unit
Old Mar 1, 2012 | 09:39 AM
  #54
EVOizmm's Avatar
If you do repack the rear diff, you should probably put your stock rear sway bar back on. or leave it off completely.
Extreme, what are you doing for aero? any undertray/splitter, wing upgrades?
Old Mar 1, 2012 | 10:03 AM
  #55
ExtremeDSM's Avatar
As for aero, I have not even thought about it yet. I may have VPT do something for me. As for big hukinani wing, NO. I cannot stand how the aero stuff looks.
Old Mar 1, 2012 | 11:16 AM
  #56
R/TErnie's Avatar
TRE makes a billet side cover and makes the bearing MUCH bigger to support 3x the load.
TRE also sets up the rear end... remember it's a ring and pinion. Shot peens both, does gear detailing, and then aligns them properly and shims as necessary. I don't think many of these homebuilt units have their contact area blueprinted like TRE.
TRE has a rear sight glass so you can monitor your rear diff fluid level. Very handy! Moves the fill plug to a higher point to make sure the bearing is getting fluid, controls rear diff temperature when you're doubling the torque going through the diff.
You'd be an ignorant fool to think you could rebuild a rear differential at your home in your garage PROPERLY. If you think you can... you're either ignorant of what tools are required to do the job properly... or you're one of those people who think if it works... it must be right.
Old Mar 1, 2012 | 11:56 AM
  #57
Maybe thats why some people break them (repacked stock) and others dont, I dont want to turn this into a diff discussion but i know Extreme has interest in this and i had been seriously considering repacking the stock one but decided not to because of the longevity issues that some were seeing.
How is your TRE unit for the average Joe driver is the tail end still easily controlled or have you found yourself driving at or over the limit a lot more? Does it only come on strong when your applying throttle or also on Decel?
Old Mar 1, 2012 | 11:58 AM
  #58
mullen's Avatar
Im not doubting there quality.
Old Mar 1, 2012 | 12:02 PM
  #59
ExtremeDSM's Avatar
Yeah, what Getsideways said.
Old Mar 1, 2012 | 04:52 PM
  #60
ExtremeDSM's Avatar
Sticky icky's!!!
Uploaded with ImageShack.us
