What class for me now?
Old Oct 11, 2012 | 06:44 AM
PatricksEvilEvo's Avatar
Ok I've done some searching and I'm a bit off on which class I'll be in for 2013 SCCA and if it's "legal" with an open 02 dump because this thing is crazy loud. Here are the mods for next season.
Motor
I'll just say Evo 9 (Mivec+9 turbo)
02 dump
3"tbe w/test pipe
Wally 255
1050cc injectors
AMS fuel rail
AMS intercooler
AMS lower IC pipe
GReddy upper pipe
ported TB
ported intake manifold
ported exhaust manifold
Spoolin up cop
272 cams
E98 tune at 30psi
Suspension
Bilstein HD's
Spec-R's
Whiteline front/Perrin rear sways
Megan LCR's
Tein camber plates
Interior
Autopower bolt in rear section roll bar (with metal "slabs" welded down)
Sparco Evo 2 Plus driver seat
Schroth 5 point harness
Wheels
Stock Viii rims
BFG G-Force TA's
Old Oct 11, 2012 | 11:42 AM
GTisRule's Avatar
Motor
02 dump
3"tbe w/test pipe
Wally 255
1050cc injectors
AMS fuel rail
AMS intercooler
AMS lower IC pipe
GReddy upper pipe
ported TB
Spoolin up cop
272 cams
E98 tune at 30psi
Suspension
Bilstein HD's
Spec-R's
Megan LCR's
Tein camber plates
Interior
Wheels
Stock Viii rims
BFG G-Force TA's
LOL, STO, have fun!
Old Oct 11, 2012 | 11:57 AM
GTisRule's Avatar
On the dump I'm not sure. I do believe all STx cars must have the exhaust exit after the front axles. I run one too but with our local hillclimbs they're prettily lax.
Old Oct 11, 2012 | 12:56 PM
Dallas J's Avatar
Veteran: Army
Injectors, Cams, Fuel Rail, Ported intake & exhaust, COP, o2 dump... all put you In SM.
Dallas J's Avatar
Veteran: Army
Dump may or may not make you illegal in any class if you're too loud.
Old Oct 11, 2012 | 01:23 PM
Meathooker's Avatar
it was my understanding even in FP the exhaust has to exit behind the front wheel, not sure how and open dump is classified. some bigger venues have a Db meter and check for sound levels, so that could bump you as well. If neither of those is applicable then SM as dallas stated
IMO we are having a hard time maintaining sites to race on as it is, obnoxiously loud vehicles doesnt help our cause, not does it make you faster.
Old Oct 11, 2012 | 01:39 PM
chu's Avatar
chu
THis.
Old Oct 11, 2012 | 02:18 PM
Dallas J's Avatar
Veteran: Army
This is a great point. Good sites are hard to come by, don't be the guy who pisses off the owner with an annoying dump just to sound cool (and it doesn't make you faster )
Old Oct 11, 2012 | 02:22 PM
Ok so maybe I went a bit too far for scca autox but I drag race it as well. I have to beat 760 in the 8th to beat my buddys big block Nova. Should be no problem
Old Oct 11, 2012 | 02:24 PM
It's been proven to put out more power.
Old Oct 11, 2012 | 04:24 PM
Ralliart004's Avatar
Veteran: Air Force
That would put you in SM sir.
-O2 dump
-Test pipe
-cams
If you didnt have those you would pass for STX.
Old Oct 11, 2012 | 04:56 PM
RJones's Avatar
-O2 dump
-Test pipe
-cams
If we're talking autocross... the only thing that puts him in SM from your list above is the cams.
O2 dump is technically legal in STU and definitely legal in ASP as long as the dump is behind the driver. See 14.10.D and 15.10.I
Test pipe is legal in ASP, also reference 15.10.I
Old Oct 11, 2012 | 06:24 PM
Dallas J's Avatar
Veteran: Army
I was at work and going off memory but was wrong on a couple of these. Fuel is open and so is the COP. Your porting is most likely further than 1" so that wont work for ASP. Since no one makes a dump that dumps behind the driver, thats going to be illegal. Cams, definitely ASP illegal.
Old Oct 11, 2012 | 07:06 PM
I bought the car years ago with cams already in it. I don't know which set they are but they're definitely not stock. I could always get a stock set and a Megan o2 if I'd be better off.
Old Oct 12, 2012 | 10:18 AM
dailygrind's Avatar
I was told...
Wally 255
1050cc injectors
Is also illegal for STU.
