Adjustable rear swaybars, what are our options?
Old Jul 3, 2013 | 01:04 PM
4wd4me's Avatar
Question Adjustable swaybars, what are our options?
What are our options for adjustable swaybars (EVO 8/9)?
autocross minded
Here's what I've compiled so far:
REAR
stock 22mm [12.29lbs including brackets/bushings]
Cusco 23mm +3% +15% +25%
Hotchkis 24mm +10% +27% +47% [6.7lbs]
Works 24mm +13% +23% +55%
Whiteline 24mm +19% +42% +67%
Progress 25mm ???
Perrin 25mm +70% +111% +167%
Robispec 26mm +?% +?% +?% +?%
Whiteline 26mm +67% + 95% +127%
Agency Power 27mm ???
Progress 27mm (discontinued)
Addco?
Ankeny?
Gendron?
Road Race Engineering?
FRONT
stock 24mm [10.93lbs including brackets/bushings]
stock DIY drilled +8% -->+20%??
H&R 25mm 2way +??% +??%
Tanabe 25.4mm +??% non-adjustable, hollow, .125 wall thickness [7.8lbs]
Whiteline 26mm +38% non-adjustable
Cusco adjustable front bar mounts: -14%, 0%, +16%
Old Jul 3, 2013 | 01:43 PM
sujinX's Avatar
the road race engineering one is the progress. i like it because it comes with the mounts. i picked it specifically for that reinforcement.
its a 3 way
Old Jul 3, 2013 | 03:43 PM
4wd4me's Avatar
its a 3 way
any idea what the percentages over stock are?
Old Jul 3, 2013 | 04:14 PM
RJones's Avatar
Robispec makes (or at least used to make) a 26mm 4-way bar.
Old Jul 3, 2013 | 04:28 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Front bars are equally as important, why not compile those as well?
Old Jul 3, 2013 | 05:05 PM
RJones's Avatar
I think Doug mentioned that this is "autocross minded" because a lot of focus in autocross is on the rear bar, not necessarily the front, especially in STU, where he runs his car. I do agree that the front bar is also important though. In fact, I have an upgraded front bar and stock rear bar in my SM car.
Old Jul 4, 2013 | 10:55 AM
4wd4me's Avatar
Yeah, good idea. I will edit my OP... and to reiterate, I am looking for help on collecting sway specifications (rear in particular) for the 8/9, as a percentage over stock.
Old Jul 4, 2013 | 01:18 PM
RJones's Avatar
Don't forget about the Cusco adjustable front bar mounts. -14%, 0%, +16%
Old Jul 12, 2013 | 04:39 PM
artinist's Avatar
dont forget the hotchkis rear bar hollow. its supper light and works well. don't know why anyone would get anything else.
the Tanabe front bar is hollow also
Old Jul 12, 2013 | 06:07 PM
griceiv's Avatar
it's too small.
Old Jul 13, 2013 | 05:49 AM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Maybe add weights?
Hotchkis rear is 6.7 lbs
https://www.evolutionm.net/forums/10692762-post350.html
Tanabe front is 7.8 lbs
http://highboostforum.com/forum/show...n-thread/page4
There are weights for the stock bar as well.
Old Jul 13, 2013 | 08:43 AM
Ralliart004's Avatar
Veteran: Air Force
I personally run the 'Rampage (HKS UK)' tarmac setup. It was something that was popularized for their tarmac rally stages and endurance race cars. If there was a need for some more front balance a whitline front on soft could be added.
Drilled front stock and whiteline 26mm on medium.
Look up the settings for the R4 ct9a rally car and those make a good platform to start from.
Car is nicely balanced but you have to toss it... the front feels like more understeer but all the data and times show more grip. If you have ever driven a heavily suspensioned subaru you know what i mean about having to toss it to turn.
Old Jul 15, 2013 | 09:38 AM
4wd4me's Avatar
Originally Posted by griceiv
it's too small.
I haven't had much luck finding what I'm looking for so far, anybody out there we know in the evo/autox community have a custom rear bar put together?
..Ankeny? Gendron?
Old Jul 15, 2013 | 05:06 PM
4wd4me's Avatar
I've seen this mentioned a few times now... was there once an adjustable front bar from Whiteline? if so, what happened to it?
Old Jul 15, 2013 | 05:13 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Have you already tried reaching out to the manufacturers?
Mention you're compiling a list for the Evo community, I bet they help out in the interest of possible future sales.
