-20 an hose options
-20 an hose options
I'm looking for something more flexible than the typical ss braid. I know they don't make pro classic and proflex in -20. My requirements are only that it uses an female -20 fittings on each end. Solutions? I can't find barbed fittings that big for an, but I'm open to ideas ( must also look reasonable no scabbing)
What about this?
https://www.pegasusautoracing.com/pr...p?Product=3490
And hose ends here:
https://www.pegasusautoracing.com/pr...p?Product=3271
And hose ends here:
http://www.siliconehose.com/silicone...od-0-200-wall/
http://www.boostcontroller.com/index.php?item=365&ret=http%3A%2F%
I was thinking an 20 fittings with this. Seems tht 1.25 Id is too big to use a normal an 20 fitting and clamp it on because -20 is really 11/8. Wish I had a wrc budget haaahhh
I'd assume with those hose ends I listed up above, you're going to need something with a PTFE liner like that starlite stuff.
I just went back and actually looked at the price of that stuff. $90/ft. Ow. At least the hose ends are only $65.
Yea, If I could find a -20 barbed hose fitting I'd be good to go. I'm only moving coldside air to a wastegate mounted off off the manifold. Things are shielded nicely so radiant heat is lower.
130 in fitting + 270 in hose! Out of my league! Lol ill end up having to go ss braid
rubs the hell out of stuff and bends poorly
That $90/ft seemed wrong, lookee here:
http://www.hrpworld.com/index.cfm?tp...action=product
$16.59/ft.
And if you look at their hose fittings:
http://www.hrpworld.com/index.cfm?tp...ction=category
Seem to be cheaper as well.
$16.59/ft.
Turning a tial wastegate into a fresh air valve: the real wrc fresh air valve is 1800usd
Ill start a thread here in the motor sports thread once I get some things (vipec, star lite hose etc)
EGbeater
28
Jul 18, 2019 01:24 PM
EGbeater
38
Apr 25, 2015 10:22 AM
DreamerAndy
May 11, 2012 06:20 AM
trinydex
Mar 29, 2007 05:46 PM
