OFFICIAL: Autocross Videos
#139
First event in the evo since nationals last year. Grabbed the old camera, but forgot to check the mount... so sorry about the shakey video and vibration noise.
https://youtu.be/O3IHiilWEOM
Zack
#146
so, here's my last event from last year with the same club and very similar course. the only significant difference is the cusco, the rest of the car had some minor tweaks here and there but nothing significant.
and with the osg
not great driving i realize, and a lot of distance to cones. not a huge difference i see in the car's performance overall
and with the osg
#147
video from this past weekend -
The car is feeling better with the rear bar on the middle setting, though it was cooler out. Also switched from the RT615k+ to the RE71Rs and feels like I've gained at least a second.
I'm still not loving how the OS Giken feels, it feels like I'm waiting for the diff to lock before the power really goes down.
Starts with my fastest run (4th) and then runs 1-6. Biggest thing I noticed from the last event is how much time is eaten from not slowing down enough for the corner to exit out
#148
Man, the car just looks painful to drive though it does seem like a lot of self-induced push in there. The biggest thing I notice, especially after your first run, is you don't start turning the wheel till you want the car to be turning. You need to be easing wheel into the turn and as it loads up the outside you can be feeding in harder. When the car is softish like yours, you have to be even slower with the hands because the car needs time to get rolled over and take a set. I feel like you're getting your hands turned all the way into the turn faster than the car can take a set into what you're trying to do.
The first vid, which is your best for sure, is so much better than the 1st couple runs (2 and on) where youre just late on everything and way off line. The big thing I always feel about the evo is you have to be on line and not over drive into a corner. Once you got to hard into a corner its impossible to fix, youve just lost time. Its just the nature of the front heavy car because at that point all you can do is overload the front and then it doesnt have enough work remaining to get the rear to move.
Cause of wind noise I can really get a feel for how your exits are going to see if you're just asking the car to accelerate too soon or what but overall i'd say exits looked ok. It mostly just looks like you need more rear spring, and use camber and toe to keep it stable. You need to get the front to do less work.
kyoo (Apr 30, 2019)
#149
My video from Sunday with Texas SCCA at Texas Motor Speedway. It was a fast course and a surface I'm used to but my car was unusually prone to oversteer. I still managed a class win by a couple of seconds but I was upset because I only managed a meager 0.3 seconds over my first run. The other way to look at it is that I finally put down a heater run on my first run; I'm going to go with that.
#150
